SHARP LC-60LE752E: TVN Player Icon Vanishes on AQUOS NET+ Receiver - Update & Factory Reset
piotr_73_1973 10071 8
  • #1 16568810
    piotr_73_1973
    Hello. Yesterday I noticed the disappearance of the tvn player icon in the tv receiver (AQUOS NET +). The update does not find a new software, the factory settings also do not contribute anything. The player was and disappeared. Can anyone help?
  • #3 16572951
    piotr_73_1973
    I wrote. we will see what they will write back. thanks
  • #4 16581866
    piotr_73_1973
    Hello. They wrote that applications can change, they have no influence on it and they do not bear responsibility which websites put on AQUOS NET +.
  • #5 16581913
    Korando1245
    Rate: 32
    So it comes out that the update has made changes and the tvn player is not included in it. You can still try to write to the tvn player, maybe they have to do it
  • #6 16581922
    _kli_
    Help: 764
    Rate: 1042
    For me on Sharp 39LE350 is TVN Player (AQUOS NET +). Apparently depends on the tv model.
  • #7 16582241
    AxelNext
    Help: 265
    Rate: 454
    From my SHARP 46LE830 TVN Player it disappeared a few years ago and has not appeared yet.
    AQUOS NET + from SHARP is one big failure.
  • #8 16583868
    kcala93
    I wrote to the Player and I received information that the producer of this TV has ended support for the TVN PLAYER application and therefore it will not be possible to use their content.
  • #9 16583901
    Korando1245
    Rate: 32
    So I thought that the update is no longer a player.
The discussion revolves around the disappearance of the TVN Player icon from the AQUOS NET+ interface on the SHARP LC-60LE752E television. The user attempted to resolve the issue through software updates and factory resets, but these efforts were unsuccessful. Responses indicate that the absence of the TVN Player may be due to changes in application support, as confirmed by SHARP, which stated they do not control the applications available on AQUOS NET+. Other users reported similar experiences with different SHARP models, suggesting that the issue may be model-dependent and linked to the discontinuation of support for the TVN Player application.
