[Solved] SHARP LC-49UI8872ES TV: Need USB Firmware Update for Intermittent Startup Issues
cheverme 3369 4
  • #1 20040643
    cheverme
    Hello! Can you help me please? I am looking for USB firmware for SHARP TV model LC-49UI8872ES. The TV sometimes turns on normally and sometimes stays 30 seconds on the logo and turns off.
    Serial No.: A49UI8872ES37B39116580701418
    Display: LSC490FN02
    Main board: T.MS6488E.U703
    billobirillo
    Help: 338
    Rate: 801
    you have a private message: check it!
  • #3 20041749
    cheverme
    Many thanks billobirillo! I will try and write about the results.
  • #4 20060626
    cheverme
    Thanks billobirillo! After update, TV worked again!
  • #5 20077600
    cheverme
    The TV works normally for 15 days after the software update. Thanks!
