Sharp LC-40FG5242E Smart TV - 'No Memory' Message During Movie Playback
wektor12 15123 8
  • #1 17197685
    wektor12
    Hello, I have purchased TV Sharp LC-40FG5242E Smart tv. And I have such a problem that when watching a movie, eg on a CDA, after a few minutes, the message "No memory" appears. Maybe someone will help me in this matter, because I do not know what to do ...
  • #2 17201322
    Polon_us
    Help: 1184
    Rate: 1281
    You can try to delete any unnecessary and unused applications installed on this TV.
    From what I have read, generally the problem is caused by the excess of installed applications on TV.
    And each application takes up some memory.
  • #3 17268693
    Sharp-app
    I have the same problem and I can not remove the application ... Do you know how to do it?
  • #4 17268715
    Polon_us
    Help: 1184
    Rate: 1281
    The TV's instructions are not on hand?
  • #5 17268967
    Limanniel
    Rate: 8
    The manual has nothing to delete the application.
  • #6 17391068
    Knigusek
    Rate: 16
    Hello. Maybe someone knows how to delete all unnecessary applications from Sharp 5242, or what to do to be able to watch movies from the Internet? Connecting the portable memory does not give anything. no information in the instructions.
  • #7 17391612
    Polon_us
    Help: 1184
    Rate: 1281
    From the instructions on the TV ...
    " To remove an unwanted app from the "My Apps" list, you
    must highlight the app you want to delete and press GREEN button
    In my free translation;
    To remove an application from the list of "My applications (Favorites?)" Select the application to delete and
    then press the Green button.
  • #8 17400088
    Knigusek
    Rate: 16
    Hello. It is a pity that you can not help me. In my favorite applications, I'm empty because I do not use them and I did not put anything in there. In net + I have 82 redundant applications and I can not get rid of them. Only the phone to the company is left, maybe somebody is competent enough to tell me if there is anything to do about it
  • #9 17417327
    Knigusek
    Rate: 16
The discussion revolves around the issue of a "No memory" message appearing on the Sharp LC-40FG5242E Smart TV during movie playback, particularly when using applications like CDA. Users suggest that the problem may stem from an excess of installed applications consuming memory. Several participants express difficulty in removing unnecessary applications, with some noting that the TV's manual does not provide clear instructions for this process. A solution offered includes highlighting the unwanted app and pressing the GREEN button to delete it. However, some users report having numerous redundant applications and seek further assistance, indicating a need for clearer guidance on managing app storage and memory on the device.
