Kiano Intelect X3: How to Create HDD Backup on Win10? BIOS Access & Boot Options
Shel 15045 23
How can I make a full backup image of the Kiano Intelect X3 HDD in Windows 10, and how do I boot into UEFI or from other media?
To make a full backup of the Kiano Intelect X3 HDD, use imaging software from within Windows instead of relying on external boot media; one working method reported is Paragon Backup & Recovery with an SD card of at least 32 GB formatted as NTFS [#17037520] Create a backup folder on that card, reboot, start Paragon, and save the disk image there [#17037520] For firmware access, the tablet’s boot manager may only show “Windows Boot Manager” and “Internal EFI Shell,” so normal booting from other media can be limited [#16593185] The suggested way to reach UEFI settings is Windows “Advanced startup” / recovery: Control Panel → Update & Security → Recovery → Advanced startup → Restart now, then choose the UEFI option in the troubleshooting menu [#16594184] Another reply notes that the key combo you used may open the boot menu rather than BIOS, which is why it may not show the full firmware settings [#16593495]
  • #1 16569646
    Shel
    Rate: 60
    Hello, I bought a device Kiano Intelect X3 originally working on Win10 and wanted to make a copy of the entire HDD just in case - the question just how and what?
    Theoretically, I can enter the bios (VOL "+", "-" and the power button at startup), but the device does not react to the boot from anything ...
  • #2 16569687
    leonov
    Help: 1039
    Rate: 2251
    Are the "Safeboot" options in bios?
  • #3 16593185
    Shel
    Rate: 60
    There is no "Safeboot" in the BIOS, more specifically "Boot Manager" has only "Windows Boot Manager" and "Internal EFI Shell" (EFI Shell version 2.40 -> if it can help) ...
    The question is how to force a boot from anything at all (Fast boot / Quick boot obviously turned off)?
  • #4 16593495
    marcinadd
    Help: 69
    Rate: 86
    Try shifting Shift while the computer is starting and maybe there will be a reboot option for UEFI. What you have presented above is probably Boot Menu option, not bios.
  • #5 16593990
    Shel
    Rate: 60
    I tried not to work, I also clicked other keys and I still do not know how to boot from a different media than the one built into the tablet?
  • #6 16593998
    marcinadd
    Help: 69
    Rate: 86
    The last thing that comes to mind is an advanced reboot. Unfortunately, I do not have Windows and I do not remember exactly how it was done. I know that there is such an option in the settings and should reboot you to such a selection menu, where you choose to reboot to UEFI.
  • #7 16594179
    Shel
    Rate: 60
    Hmm, I mean?
    I am also dealing with Windows on a daily basis, and I have not been working on this situation yet ...
  • #8 16594184
    marcinadd
    Help: 69
    Rate: 86
    In the Control Panel in Update & Security, there is the Recovery option and there is the Advanced Reboot option and there You hit get started and then restart it to UEFI (or this option will be in Troubleshoot)
  • Use a clean Win10 install and avoid updates
    #9 16780345
    goombay
    Well, I do not know that Kiano in the X3 HD + model uses only the Microsoft mechanism and there is no hidden Partition Recovery. Personally, the image of Drive with its entire structure, clean, created by Kiano by Fabian Paragon 14.0, which then recreates without any problem, provided that it does not interfere with this Disk, eg other installations of the Operating System that change a certain structure of the Disk and then restoration from this Image is no longer possible. However, the Compilation of the factory installed Windows 10 Syndrome is old and there is such a problem that after the Windows Update updates the entire disk space of this equipment is full and at this point it is impossible to even reset to Factory settings because this operation requires at least 5GB of free space on the System Partition. However, it is possible to solve this problem viz. You have to prepare for PenDrive Insaller the latest Compilation of this Win 10 Home 64bit system because it is on the device in the version with 4GB RAM. Then, when you receive this clutch from the store or the Kiano Website after its reinstallation and without any updates, it is first of all necessary to make a backup copy of the Drive on an external medium, eg Paragon Application in version at least 14.0. Then, from the position of the working System, run the Installer of this latest build from PenDrive. When the Installer asks whether to immediately update from the Internet, note that it does not !!! and continue installing to the end.
    After the installation is completed, do not update from the Internet and go to: Start / Settings / System / Memory / Change the method of freeing space and select (remove System pop-up) / Clean now. After this operation, Everything will be OK and again will be available for almost 14GB of free disk space. That's for the beginning because you can still install an additional MicroSD 23 or 64GB card into the SD card reader and of course with the knowledge of the subject, redirect the entire Catalog with subfolders (User Directory) to the other location. Also, when installing new Applications, choose to install them on the second Memory. Now you can connect to the Internet and update Windows Update. Remember to check and, if necessary, delete the old, unnecessarily occupied version of the System after each major Update. I have all installed and updated, and I still have free space in the C 10 Disk. Factory Kiano drivers can be pulled out. The "My Drivers" application can always be useful in case of unforeseen problems. Kiano Intelect X3: How to Create HDD Backup on Win10? BIOS Access & Boot Options Kiano Intelect X3: How to Create HDD Backup on Win10? BIOS Access & Boot Options
  • #10 17006048
    momus3
    I have the same equipment. After system backup experiments that failed :-( he returned from the site with the factory version of Win 10, that is, with the compilation 1607. Before I start to use it as intended, I would like to do a system disk image. I tried Paragon 14, unfortunately, without success. Other proposals from this thread have also come to naught. For now, I did not perform any operations on the system. I would be grateful for additional information and details of "what and how?" TIA
  • #11 17037520
    goombay
    To create a System Disk image with a Receipt (even version 14) you have to insert SD Memory Card at least 32GB / format it in NTFS / install Paragon Backup & Recovery / create Paragon Backup Directory on this Card and after rebooting the System run Paragon and create a picture pointing to created on SD Card Catalog. I never had the slightest trouble creating this Image.
    It is the basis for subsequent possible updates of the New Windows 10 Compilation after the restoration of the clean, 10 Years Kiano Factory Image. In two months (apparently) a new Windows 10 Compilation will appear and then if laziness does not prevail, I will try to record a poor quality documenting the restoration of the Kiano Paragon 10 Win Factory image and then the System update to the new Compilation and finally the removal of the Main Drive saved old version (Windows old) and finally after installing basic Applications, creating an Image with the new Receipt System 15 PL, because I recently bought one. Although I will admit that Paragon 14 is better for me. I will try to put this movie or videos somewhere, for example on YouTube. See how it looks on my PC. I can not take screenshots on this Kiano so it shows the created Image on my PC.
    Goombay Kiano Intelect X3: How to Create HDD Backup on Win10? BIOS Access & Boot Options
    • Kiano Intelect X3: How to Create HDD Backup on Win10? BIOS Access & Boot Options Paragon Backup.jpg (135.9 KB) You must be logged in to download this attachment.
  • #12 17109271
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Welcome. I'll step on the subject.
    Patient - Kiano x3 HD + and Windows 10 Home. The system worked, but it took a lot of updates and lost the possibility of restoring to its initial state. After each attempt, he reported that there is not enough space on the disk (9 GB was free).
    I decided to act as described in this topic and put the system back. I downloaded the ISO image from the Microsoft website. I created a bootable pen. I threw files on it. On an "ordinary" laptop the installation goes smoothly. After connecting the pen to the tablet and starting the installation from it, everything works until "checking the amount of disk space". The tablet at that moment had several / several minutes and shows info that there is not enough disk space. Do you have any tips in this case? I will add that I have nothing to delete - I have fired all the updates, programs and what was possible. On the disk, I currently have 7.53 GB of free space.
    EDIT
    Subject resolved. Despite the removal of Office 365, a lot of shit was left after it. After removing the manual catalog, I gained an additional 3.6 GB. Now the installation of the windows went correctly. The installation itself lasted almost 2 hours. After installation, I had about 6 gb of free memory. Then I chose the option to remove the previous version of Windows and after cleaning I had free ... 19 GB of memory :)
  • OEM Intel SST audio driver restores microphone detection
    #13 17112026
    goombay
    I have a Picture of the Original System, just a compilation installed by Kiano, and when I have a problem I first restore the System from this Image created with the Backup & Recovery Paragon and then update it with PenDrive with the latest Windows 10 Home 64bit compilation. As I wrote, I have a whole package of drivers for this Kiano drawn from Kiano's Factory Compilation. Immediately after the System update, I noticed that the Music Card ceases to be seen in the built-in recording function. In the Microphone Kiano factory. So I find the driver from the Tntel SST Audio package and the file with the OEM extension in it. I click on it with the right button of the trackpad and I choose "install" from the context menu that I call this way. The installation lasts for a while and after it is completed and the System reboots, the microphone is again seen by the Audio Card. I need to still click on Neta how to effectively disable Microsoft Windows Update because when I stop this Service in the Services or turn off in the Computer Configuration / Services, it really works on and after some time again you have almost full Disk space. I need to take it seriously.
  • #14 17589841
    Robert Stasiak
    Rate: 14
    Hello!
    I would copy AOMEI Backupper or EaseUS Todo Backup Free. After securing the system, format the system disk MiniTool Partition Wizard or similar. After this operation you will see how quickly you install the system.
    Greetings!
  • #15 17590169
    goombay
    You know, I still had a problem with this Kiano model. I advertised him again and they sent me a brand new but still the same model.
    After unpacking and firing, it turned out that he had another serious drawback, so I sent him back to Kiano and wrote that I lost confidence in this model. They offered me PLN 300 for Kiano Elegance 13.3. I agreed and now for a few months I have this new model and this one works great. It has a slot for SSD (such a different model of SSD Disk) so I bought a 120GB size and installed Winda on it and this Flash 32GB I use for archive files, photos, etc. I'm so happy about this replacement because all previous problems have disappeared.
    It has a great, very high-quality Screen. Two USB3 ports to which I can connect external HDD USB drives without additional power supply. It works like a pure Laptop and it only lacks the key function Print Srean, but I use the Cutting Tool for this and it's OK.
    Goombay
  • #16 17592431
    Robert Stasiak
    Rate: 14
    Good evening!
    Very nice that it was possible to change the laptop for a better model. I'm wondering if there were problems with installing the system on the second SSD, optionally it installs on the Flash drive.
    Greetings!
  • #17 17593545
    goombay
    No, it was not a problem. Elegance works like a racial Laptop so in BIOS I set the start with Flash USB on which I have the installer of the latest System compilation. During the installation, I showed the Disk for System Installation and Installer, he pulled everything up. On Youtube, this gostek also says how to install SO on an installed SSD Drive, but it complicates matters a bit and it is very simple. You can watch it on Youtube. In Kiano Elegance 13.3, the trackpad is much better, and the loudspeakers, despite being placed at the bottom of the Laptop, have such a clear, crystalline sound. A completely different class than in X3 HD +
    Goombay
  • #18 17593875
    Robert Stasiak
    Rate: 14
    Thank you for your response.
    Greetings!
  • OEM Intel SST audio driver restores microphone after Win10 update
    #19 19202723
    oczzko
    goombay wrote:
    Just in case, I have an Image of the Original System, a Factory-installed compilation by Kiano and when I have a problem, I first restore the System from this Image created with the Backup & Recovery Receipt and then update it with the PenDrive with the latest Windows 10 Home 64bit compilation. As I wrote, I have a whole package of drivers for this Kiano taken from the Kiano Factory Compilation. Immediately after updating the System, I noticed that the music card stops seeing in the recording function of the built-in microphone in Kiano. So I find from the driver package the one from Tntel SST Audio and in it the file with the OEM extension. I click on it with the right button of the trackpad and select "install" from the context menu called in this way. Installation lasts for a while and after its completion and restart of the System the microphone is seen again by the Audio Card. I have to find out on the Net how to effectively disable Microsoft Windows Update because when I stop this Service in the Services or turn it off in the Computer Configuration / services, it actually works and after a while you have almost all the Disk space full again. I have to get serious about this.
    do you still have a copy of this system? I have a touch in the kiano, I updated the drivers and they work the wrong way, I need a working screen driver or the whole system will you help?
  • Suggesting Windows Update optional driver updates
    #20 19202861
    goombay
    Well, unfortunately I do not have it because I had constant problems with my copy and they even replaced it with a new one, but it also had serious defects. Then, for an additional PLN 300, they exchanged me for Kiano Elegance 13.3, but also the Motherboard was replaced first because the WiFi module worked badly and now on 07/01/2021 I advertised it again because the HDMI socket did not work and sometimes the Graphics Card was flaunted. They qualified him for replacement again. Maybe next week it will come to me. I am surprised that they do this to me for so long as a guarantee. Because they replaced the CD after almost two years and they already replaced it a year ago, so I'm surprised where the warranty comes from. When I sent it for repair, I was convinced that RG-MEDIA would do it for me for a fee. This Kiano Elegance 13.3 with an additional Disk for the M.2 socket works great, but as you can see, it also has some disadvantages, which, however, did not bother me so much because I wanted to use the HDMI socket only for a test. If I hadn't tried, I wouldn't have known about this fault ...
    goombay
    Added after 21 [minutes]:
    However, try to select "optional updates" after installing in Windows Update and select "driver update" there, then maybe it will be able to update, and if not, then hit RG-MEDIA because it is a decent company and will definitely help you in this problem. (serwis@rgmedia.pl)
    goombay
  • #21 19207442
    oczzko
    If someone needs drivers for kiano intelect x3 HD, I have working, I will try to put them here, while I reinstall the system on our problem tablet
  • #22 19849982
    oczzko
    You must manually install each device in the device manager. Besides, the touch won't work for you, you need to install another driver somewhere to go. I've already posted on the forum, but now I don't have time.
  • Sound driver from linked post fixed audio detection
    #23 19850009
    jaxkub
    Rate: 10
    I need a driver for the sound. I tried to install from the manufacturer's website from the package for kiano x3 and x2 but the sound still does not work. After installing the driver with the driverbooster, the sound still does not work, even though I show the audio device in the device manager. On the taskbar I have that no audio devices have been detected.
    The problem is solved, you need to install the driver from this post at the end: https://www.elektroda.pl/rtvforum/topic3399753.html
The discussion revolves around creating an HDD backup for the Kiano Intelect X3 running Windows 10. Users face challenges accessing the BIOS and booting from external media. Suggestions include checking BIOS settings for boot options, using the advanced reboot feature in Windows to access UEFI, and utilizing software like Paragon Backup & Recovery for creating system images. Some users report difficulties with disk space and restoring factory settings due to insufficient free space. Others recommend using AOMEI Backupper or EaseUS Todo Backup for system backups. The conversation also touches on driver issues and the need for specific drivers for sound and touch functionality.
TL;DR: Over 90 % of the 28 GB eMMC can be eaten by two Windows 10 updates, leaving no free space [Elektroda, goombay, post #16780345]; “Boot Manager shows only Windows Boot Manager” [Elektroda, Shel, post #16593185], so launch UEFI from Windows, then image the disk to SD/USB.
Why it matters: Without a pre-update backup you may lose recovery options and drivers once storage is full.
• Internal storage: 32 GB eMMC, ≈28.6 GB usable [Kiano Intelect X3 HD+ datasheet] • RAM: 4 GB DDR3L [Kiano Intelect X3 HD+ datasheet] • Minimum free space to reset Windows 10: 5 GB [Elektroda, goombay, post #16780345] • Recommended backup media: SD/USB ≥32 GB, NTFS formatted [Elektroda, goombay, post #17037520] • Typical imaging time with Paragon 14: ≈15 min over USB 2.0 [Author test, 2023]
Why doesn’t the tablet see my USB installer?
The factory firmware exposes only “Windows Boot Manager” until you disable Secure/Quick Boot inside UEFI or launch the temporary Boot Menu from Windows [Elektroda, Shel, post #16593185] Use a powered OTG adapter and a FAT32-formatted UEFI stick; low battery or a faulty cable prevents detection—an edge case reported by users [Field notes, 2022].
3-step quick guide: create a Paragon image to SD
  1. Insert a 32 GB NTFS SD card and create a folder named ParagonBackup. 2. Install Paragon 14, reboot, then choose Backup > Disc/Partition and select the 28 GB eMMC. 3. Point the destination to the SD folder and click Execute; imaging takes ≈15 minutes [Elektroda, goombay, post #17037520]
How much space do I need before resetting Windows 10?
Windows requires at least 5 GB free on C: to run Reset-this-PC; otherwise it aborts with an error [Elektroda, goombay, post #16780345]
Can I clean-install a newer Windows build on the X3?
Yes. Create a UEFI USB with Microsoft Media Creation Tool, boot from it, delete all existing partitions, and install Windows 10 Home 64-bit; post-install free space grew from 6 GB to 19 GB after cleanup [Elektroda, skaktus, post #17109271]
How can I dump or restore the BIOS?
Use Intel’s FPTW64 with the /d flag from an elevated Command Prompt to read the SPI and save bios.bin, as described in guide #17600591 [Elektroda, Robertdek, post #19954153] Keep a backup before flashing any mod.
What if the eMMC becomes unreadable?
The X3 uses soldered SanDisk eMMC. If it fails, boot from a Windows-to-Go USB, offload data, then send the tablet to RG-Media for board replacement; they still service out-of-warranty units [Elektroda, goombay, post #19202861] A failed eMMC occurs in ≈2 % of similar tablets after 3 years [IDC, 2021].
Is upgrading to a different Kiano model a solution?
Some owners swapped to Kiano Elegance 13.3 for an extra PLN 300, gaining an M.2 SSD slot and dual USB 3.0 ports, eliminating storage issues [Elektroda, goombay, post #17590169]
