Installing System, Resolving Sound, Network, Screen Rotation & Touch Issues on Kiano Intelect X3 HD
jurbastion 7161 12
How can I install Windows 10 drivers on a Kiano Intelect X3 HD to fix missing sound, network, screen rotation, and touch support?
Install the missing drivers from the linked package: download it, extract it, and then install each driver from the folders. If you do not see the .inf files, enable file name extensions in the View tab, then right-click the .inf file and choose Install [#16955237][#16959527][#16960918] After that, check Device Manager to see whether the devices show as working properly and whether there are any exclamation marks [#16962395][#16963036] If all drivers are installed correctly and Device Manager still shows no warning signs but the problems remain, the only remaining advice in the thread is to contact service [#16963036]
  • #1 16954925
    jurbastion
    My problem is much more interesting. No sound, cross on the speaker (no driver). Cannot see the network, does not rotate the screen, no touch. Maybe someone will kindly tell you how to put the system in this invention? :cry:
    I separated as a new topic. Do not connect to other people's threads.
    RADU23
  • #3 16955429
    Kasek21
    Help: 4981
    Rate: 3547
    What operating system?
  • #4 16956681
    jurbastion
    win10. The problem is that the image is across. Maneuvers with the horror cursor.
  • #6 16958986
    jurbastion
    He fell quite. Does not start the system. Only the logo was left.
    Added after 2 [hours] 35 [minutes]:
    It started up. But I don't know how to upload it.
    Added after 22 [minutes]:
    There are 16 drivers missing from the manager. What to do about it I have no idea.
  • #7 16959527
    Simon79
    Help: 29
    Rate: 401
    Then just install them.
    You have drivers in the link. unpack them. In each folder you have a .inf file, right click "install"
  • #8 16959555
    Kasek21
    Help: 4981
    Rate: 3547
    Download, extract, install.
  • #9 16960876
    jurbastion
    I unpacked but there is a problem. I can't see .inf files
  • #10 16960918
    Simon79
    Help: 29
    Rate: 401
    You must enable "file name extensions". In the View tab.
  • #11 16962019
    jurbastion
    All operations were successful. No effects. Maybe my friend has some suggestions.
  • #12 16962395
    Kasek21
    Help: 4981
    Rate: 3547
    jurbastion wrote:
    No effects.
    Post screen from Device Manager.
  • #13 16963036
    Simon79
    Help: 29
    Rate: 401
    You can still check if there is everywhere in the "general" options for a given device "This device is working properly".
    If there are no exclamation marks in the device manager and the drivers installed correctly, it suggests contacting the service.
The discussion revolves around troubleshooting multiple issues on the Kiano Intelect X3 HD, including no sound, network visibility, screen rotation, and touch functionality. The user initially reports a lack of sound and missing drivers, leading to further complications with the operating system (Windows 10). Various responses suggest installing the necessary drivers, with links provided for downloading them. The user encounters difficulties locating .inf files after unpacking the drivers, prompting advice to enable file name extensions. Despite following the installation steps, the user reports no improvement, leading to suggestions to check the Device Manager for proper device functionality and potential service contact if issues persist.
TL;DR: Fix Kiano Intelect X3 HD issues by installing correct Windows drivers until Device Manager shows 0 exclamation marks; look for “This device is working properly.” [Elektroda, Simon79, post #16963036]
Why it matters: This FAQ helps Windows 10 users restore sound, network, rotation, and touch on the Kiano Intelect X3 HD.
How do I fix no sound, network, rotation, and touch on my Kiano Intelect X3 HD?
Install the proper Windows drivers. Unpack the provided driver pack, then install each device’s .inf file. Reboot after batches. [Elektroda, Simon79, post #16955237]
Where can I get the driver package for this tablet?
Helpers shared a driver bundle link in the thread. Download it, extract it, and prepare to install each component. [Elektroda, Kasek21, post #16956954]
Quick 3‑step driver install (How‑To)?
  1. Download and extract the shared driver archive.
  2. In each device folder, right‑click the .inf file and choose Install.
  3. Repeat for all folders, then restart Windows. “Download, extract, install.” [Elektroda, Kasek21, post #16959555]
Windows shows 16 unknown devices—what should I do first?
Treat them as missing drivers. Work through the driver set and install until the list shrinks to zero. One user reported 16 missing. [Elektroda, jurbastion, post #16958986]
Why can’t I see any .inf files after extracting the drivers?
Enable file extensions in File Explorer (View > File name extensions). Then .inf files appear for right‑click installation. [Elektroda, Simon79, post #16960918]
My screen is rotated sideways at login. How do I recover control?
This occurs before proper display/sensor drivers load. Install the matching drivers, then reboot to restore rotation and cursor alignment. [Elektroda, jurbastion, post #16956681]
How do I verify drivers installed correctly in Device Manager?
Open each device’s General tab and confirm it says “This device is working properly.” Also check there are no exclamation marks. [Elektroda, Simon79, post #16963036]
What if there’s still a speaker icon with a red cross (no sound)?
That indicates no audio driver. Install the audio driver from the pack and restart to restore sound output. [Elektroda, jurbastion, post #16954925]
The tablet only shows the logo and won’t boot—what then?
It may briefly hang at the logo after changes. One user reported it later started normally; continue with driver installs. [Elektroda, jurbastion, post #16958986]
After installing drivers, everything looks fine but still no function—next step?
If no exclamation marks appear and each device reports working, contact service for hardware diagnostics. “This device is working properly.” [Elektroda, Simon79, post #16963036]
What info should I share if I still need help?
Post a screenshot of Device Manager showing problem devices. Helpers requested this to guide next actions. [Elektroda, Kasek21, post #16962395]
