[Solved] Kiano Intelect X3 HD - No Audio Output Device Installed after Windows 10 Upgrade
m.pisarski17 11043 4
  • #1 16836229
    m.pisarski17
    In my Kiano Intelect X3 HD sound does not work after installing Windows 10. I get the message "No audio output device installed" I installed the manufacturer's drivers but it does not work. The drivers seem to be installed well, there are no errors in the device manager. Anyone had a similar problem?
  • #2 16836252
    RADU23
    Help: 2428
    Rate: 1732
    Post a screen from the device manager with the "sound controllers" tab expanded.
    m.pisarski17 wrote:
    sound does not work after installing windows 10
    Previously what was the system?
  • #3 16836961
    m.pisarski17
    Earlier windows 10 and everything worked
  • #4 16839042
    m.pisarski17
    Screenshot like everything is ok but not working
    • IMG_20171121_121559.jpg (5.27 MB) You must be logged in to download this attachment.
  • #5 17260115
    robs001b
    Rate: 13
    The solution to the problem is to install an older version of the Intel SST Audio Device (WDM) drivers
    link
    • link.txt (82 Bytes) You must be logged in to download this attachment.
