TGA Windshield Wipers Not Working - Relay, Motor Replacement, Wiring Diagram & Troubleshooting
marcing1988 9999 7
  • #1 16571752
    marcing1988
    As the topic. The wipers are not working. After turning on the switch, the Cpyka relay once, after turning it on again, is no longer audible, and after waiting a few moments, it will knock once again and no response. I replaced the engine with a new one, but the new one did not work either. Maybe someone does something like this, maybe someone has a diagram or will tell you where to look for?
  • #2 16571804
    svavecone
    Help: 73
    Rate: 456
    Since you have replaced the motor, the next step is to diagnose the combined switch itself. You can suspect its operation in the diagnostic computer.
  • #3 16572302
    Heroses
    Help: 71
    Rate: 160
    Have you checked the relay ?? the shifters themselves often fall in the mana. Today, fortunately, you can buy a second one for little money. If you don't think about anything, I will send you a piece of the diagram.
  • #4 16580650
    marcing1988
    I changed the relay and it works after turning on the handle, it pops and after turning it off, it will also knock correctly, i.e. correctly, I also checked the current on the relay contacts and also there is everything ok. why nothing worked after connecting the new one? If someone knows when and what voltage should be on the ankle contacts from the wiper motor, please give me a hint.
  • #5 16581429
    Cobrat
    Help: 35
    Rate: 502
    If you replaced the motor with a new, cheap one from the "ladybug", there is a probability that it was also worth nothing. Even change the stimulant, but 1000% efficient.
  • #6 16582836
    Heroses
    Help: 71
    Rate: 160
    when the engine got hot you have a seized wiper mechanism.
  • #7 16586015
    marcing1988
    Today I took the cable off the engine and the engine was almost dead. Can someone describe the pins of this engine or provide some installation diagram?
  • #8 16608546
    Hart3
    Help: 100
    Rate: 479
    If it is helpful, I am sending a schematic diagram.
    • MAN TGA-wycieraczki.zip (81.3 KB) You must be logged in to download this attachment.
The discussion revolves around troubleshooting non-functional windshield wipers on a TGA vehicle. The user initially replaced the wiper motor but continued to experience issues, including an audible relay click without wiper movement. Responses suggest checking the combined switch and relay functionality, as well as the possibility of a faulty replacement motor. The user confirmed the relay was replaced and showed proper operation, but the wiper motor still failed to work. Further inquiries were made regarding the wiring and voltage specifications for the motor. A schematic diagram was offered to assist in the troubleshooting process.
