[Solved] Golf V Wipers Malfunction: Motor Check, Fuse Inspection & Connection Issues
arturmurek 39495 8
  • Suspected signal wire fault in Golf V wiper circuit
    #1 16971463
    arturmurek
    Rate: 36
    Hello. I have had a problem with golf wipers for a long time v. Two weeks ago in the morning when the wipers went to work did not work, I checked the fuses and the connection of the wiper motor But everything looked ok. After returning I went to the car again and everything was ok. In two days going shopping the wipers themselves started to work and turned off. Again after a while everything returned to normal. 2 days ago the wipers died completely. Nothing helps anymore: I checked the motor cube, ok, I think there are three cables plus constant weight and I think plus signal. I checked the engine for a short time and it did not work, of course I bought a second one and connected it on the cord for a while and everything was going on. I came back home, set up the engine, connected the ankle and nothing. It won't even move. I will add that the mechanisms because I already have two move without any resistance, i.e. they are certainly not blurred. I checked the current on the ankle from the motor and I do not know how it should be normal, but when connecting the solid plus mass to the light bulb everything is OK, but when I connect this purple-white signal with mass or with a plus, nothing burns. Car checked on a closed bonnet. There are no errors in the computer.
    Auto to golf v 2.0 tdi 16v engine code BKD 2004. Please help ...
  • #2 16971490
    andrzej20001
    Help: 1578
    Rate: 6669
    Rope controlled engine from bordnetz. You've got to have a plus on black. Brown mass. Checked with a light bulb. Thin is a digital signal. It remains a vag test. Unless the genius founded Czajna xenons
  • #3 16971532
    arturmurek
    Rate: 36
    I founded but led Philips on passing. And what happens when the Chinese connect? As for the cables, it is red brown and purple white.
  • #4 16971555
    dabu
    Level 32  
    Help: 190
    Rate: 695
    The tip in the mask is working?
  • Suspected hood switch fault and motor burnout
    #5 16971586
    arturmurek
    Rate: 36
    Some time ago I replaced the grill in the front and saw there two cables connected to the lock and even the clocks showed me an open mask. Not long ago I noticed that one is torn off but when I open the mask it doesn't show me open. The mechanic checked the current on the ankle when it was closed and open, and each time the current reached it. The problem is that I have two engines and none work even briefly. As soon as I connect a new engine, after a while it stops working as if it burned.
  • #7 16971628
    arturmurek
    Rate: 36
    What should I check now? Tomorrow I will dismantle the grill and fix this cable in the castle. And this v216 driver is where it is located?
    And as for these bulbs, what can they damage? Maybe my Philips leds also damaged something.
  • #8 17047156
    arturmurek
    Rate: 36
    Windshield wipers repaired. The problem was in the wiper control computer. The wiper motor cannot be connected for short periods even to check. I close the topic.
  • #9 17047162
    arturmurek
    Rate: 36
The discussion revolves around a malfunctioning wiper system in a Golf V vehicle. The user initially reported intermittent wiper operation, followed by complete failure. They checked the fuses, motor connections, and replaced the wiper motor, but the issue persisted. Various responses suggested checking the wiring, particularly a torn cable connected to the lock, and the possibility of a faulty wiper control computer. Ultimately, the user confirmed that the problem was indeed with the wiper control computer, which prevented the motor from functioning properly.
