Passat B6 Windscreen Washers Not Working: Checked Fuses, Relay, Motor - Need Help Troubleshooting
radek8607 57906 7
  • #1 16879444
    radek8607
    Rate: 52
    Hello, I do not work in the passat windscreen washes I've probably checked everything fuses relay under the steering wheel pulled out the engine and I plugged in for a short time and it works, I hooked another gear today and also does not work. Help
  • #2 16879495
    PREDAT
    Help: 76
    Rate: 141
    If my memory does not go wrong, then there should be 2 relays from the washer, left right revs, (front, back) Both work? When trying to spray, they speak and the wipers are working?
    piwko
    Help: 87
    Rate: 213
    The cigarette lighter socket works?
  • #4 16879617
    radek8607
    Rate: 52
    Yes, I exchanged both of these transmitters and nothing and the wipers normally work, I try to spray
    Did not work
  • #5 16879640
    piwko
    Help: 87
    Rate: 213
    Did not work
    Of course, you checked the fuse, it was you to replace the 70A relay in the lower right corner of the bordnetza or body of the computer.
    If you do not have it, it will replace the right one with the left one. If I'm not mistaken, there are two, I write from memory.
  • #6 16879663
    PREDAT
    Help: 76
    Rate: 141
    Well, unless it is missing (depends on what was the fault history) of the fuse under the hood of this maxi.
    (SB49-51 I do not remember) Sometimes I had such failures straight out of the fault :D
  • #7 16879683
    piwko
    Help: 87
    Rate: 213
    These relays were often raining, I had a few where the coil got a break.
  • #8 16879853
    radek8607
    Rate: 52
    When I bought it, it would normally work so suddenly it stopped tomorrow I will check this relay again
    Added after 14 [hours] 28 [minutes]:
    And this bordnetz where is it? Under the steering wheel, where are these relays?
    Added after 5 [hours] 3 [minutes]:
    I found the reason, as my friend said, that it is a relay in the module on the bottom right side of the 70A No. 460.
The discussion revolves around troubleshooting the windscreen washers of a Passat B6, which are not functioning despite checking fuses, relays, and the motor. The user confirmed that the wipers operate normally, indicating that the issue is isolated to the washer system. Responses suggest checking two relays associated with the washer system, specifically the 70A relay located in the bordnetz (body control module) under the steering wheel. The user later identified the problem as a faulty relay in the module, confirming the relay number as 460.
