Fiat Seicento 900 - Orange Key CODE Indicator Light Issues: Causes & Solutions for Engine Start
ciapus4 19437 3
  • #1 16578611
    ciapus4
    Level 19  
    Help: 10
    Rate: 42
    Hello, for a few days during the ride the above mentioned lamp was lit, after turning off the engine everything ok, one time he did not want to start the car, it helped to disconnect aku, but today the lime does not help what can be the cause, replacing the key the same.
  • Immobilizer fault may be triggered by low battery voltage
    #3 16580576
    sandamiano
    Help: 161
    Rate: 354
    This indicator indicates a fault in the Fiat immobilizer system. If it ignited briefly while driving, it is possible that the charging of the battery dropped below a certain value and the controller signaled it by checking the voltage. If you have a code card for this car, launch by entering the electronic code from the card using the accelerator pedal procedure - to find, for example, the pdf manual in the network.
    If you do not want to have problems with this emergency immo find an unpaved engine driver but before that unpin the immo control unit behind the fuse box in the cabin. Then you can fire without a problem if the fault is on the side of the immobilizer
  • #4 16586471
    ciapus4
    Level 19  
    Help: 10
    Rate: 42
    Thanks, and maybe there is someone from the boat what it does and erases the IMMO code from the controller I have an IAW 16FM.EC 0.9 SPI central unit, they are supposedly doing IMMO decoding without desoldering the prock.
