VW Passat B6 - Coding - no record 09 CENT. ELECT. BORDNETZ 3C0 937 049 J
AlienPL 8727 5
  • Central electrics coding not being saved
    #1 16896198
    AlienPL
    As in the subject.
    I have a problem with coding anything in 09 CENTRAL ELECTRICITY VCDSem 17.8 VCDS HEX + CAN V2 interface (I wanted to code the rear lamps only so that only the rings in the BYTE 9 positions 00 value). Other things like the warning lights on the 45 Door Electric door that I didn't have before, I coded and glowed easily. Simply in 09 CONTROL PANEL I will ask new values I will confirm, a message will appear with CODE ACCEPTED after which the lights shone as before and after entering the long coding again in 09 CENTRAL ELECTRICS shows the old coding. The problem is only in 09 Central electrics. Someone with such a problem has already met
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Yes. VCDS damaged.
  • #3 16896245
    AlienPL
    T5 wrote:
    Yes. VCDS damaged.
    broken cable?
    I will only add that I can code other things despite the central electrics
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    I did the same. I changed the cable and it went.
  • #5 16898440
    mar.wo
    Help: 10
    Rate: 84
    Either damaged 09 or cable. VCDS ori or rice?
  • #6 16908244
    AlienPL
    Problem solved. It was enough to change the VCDS versions to 16.8 and it worked. Whether original or rice, in this case did not matter as much as the statement of buying a new cable. Regards
