Opel Vectra C 2002 2.2dti Switching to Emergency Mode Unexpectedly after EGR Cleaning
piotrekrob 5058 3
  • #1 16580230
    piotrekrob
    I have a Vectra C from 2002 2.2 DTI with an autoatic box and I have a similar problem as my colleague above, except that the car drives normally and suddenly jumps into the emergency mode and you know the car lamp with the key lights up and at this point it can go out when I stand at the junction , I have to move without adding gas, only releasing the brake, somehow I will drive about 50 km / h, when the light goes out, everything goes back to normal, comes out of emergency mode and goes normally.
    it all started after cleaning the EGR, but I rather exclude the connection with this,
    Then there was also the swirl flaps for cleaning, but it did not help. I am asking for help, because in two weeks' vacation and my Viki is limping, maybe it's cold February on the pump or this shaft sensor?
    I am adding an attachment with errors.
    greetings Piotr
    • Opel Vectra C 2002 2.2dti Switching to Emergency Mode Unexpectedly after EGR Cleaning 20170710_183029.jpg (2.4 MB) You must be logged in to download this attachment.
  • #2 16580249
    CameR
    Moderator of Vehicle Security
    Help: 1136
    Rate: 3260
    ... maybe check all electrical connections in the engine compartment if there is "greens" somewhere.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16580271
    piotrekrob
    Everything was checked, there were still plugs on the pump.
  • #4 16580504
    Heroses
    Help: 71
    Rate: 159
    You also have mistakes Can maybe Cim sits down. Check the connectors on the pump, abs controller and gearbox b. See for plugs under UEC
