Opel Zafira A 2002 2.0: Power Loss, Emergency Mode Activation, RPM & Intersection Issues
Marcin szym 11568 9
Why does an Opel Zafira A 2.0 go into limp mode when it warms up and then trigger again when I accelerate from low speed?
It was not the immobilizer; the “car with a key” lamp is not an immo indicator, so the car needed proper fault-code diagnostics, and in this case the problem was fixed by replacing two valves next to the battery [#17012977][#17013020][#17025582] A scan under the computer was suggested because the warning light means there is a stored error [#17012930][#17012933] The EGR valve had already been replaced, but that did not solve it [#17012944] After the two valves near the battery were replaced, everything worked normally again [#17025582]
  • #1 17012889
    Marcin szym
    Rate: 11
    I have Opel zafira 2002 2.0 for some time when the car warms up, the emergency mode starts and when it is stretched to over 2000 thousand revolutions. This emergency mode turns off and when I turn on the gas, for example, before an intersection, it turns on again. Emergency mode. What can it be a mechanic spreads his hands (it's not egr and the hoses are also good) HELP.
    robokop
    Help: 1763
    Rate: 6371
    You have not been to any mechanic - the emergency mode is an orange lamp on the board, and if the lamp is on, then there is an error that lit it. So?
  • #3 17012933
    Mavrick
    Rate: 21
    Plug it under the computer ... maybe he will tell himself what hurts him.
  • #4 17012944
    Marcin szym
    Rate: 11
    The mechanic said that it was an EGR valve and replaced it and it did not help (and the error that lights up is a car with a key)
  • #5 17012977
    Mavrick
    Rate: 21
    A car with a key indicates a problem with immo.
  • #6 17012983
    Marcin szym
    Rate: 11
    It's like this from imob.to, if it lights up, why is the car a mule.
  • #7 17013011
    robokop
    Help: 1763
    Rate: 6371
    Is that the indicator?
  • #8 17013015
    Marcin szym
    Rate: 11
    Yes, that's right
  • #9 17013020
    robokop
    Help: 1763
    Rate: 6371
    Then please change the mechanic, or finally go to him. I close. This is not an immobilizer indicator!
  • #10 17025582
    Marcin szym
    Rate: 11
    Machanik replaced two valves that are located next to the battery and everything is fine. He deleted PLN 430.
The discussion revolves around a 2002 Opel Zafira 2.0 experiencing power loss and activation of emergency mode when the engine warms up and RPM exceeds 2000. The user reports that the emergency mode reactivates when accelerating, particularly before intersections. Initial diagnostics suggested an issue with the EGR valve, which was replaced but did not resolve the problem. Further investigation indicated a potential issue with the immobilizer system, as indicated by a warning light resembling a car with a key. Ultimately, the mechanic replaced two valves located near the battery, resolving the issue for a cost of PLN 430.
