The discussion revolves around a user unable to access the configuration page of their TPLINK router, specifically the TD-W8960N model. Initial suggestions include using the default IP address as per the router's configuration instructions. The user attempted to access the router via 192.168.0.1 but was unsuccessful. Another response indicated that the factory default address is 192.168.1.1 and recommended resetting the router's settings. The user confirmed following the instructions but still faced issues. A further inquiry was made regarding whether the connection was via LAN or Wi-Fi. AI summary based on the discussion. May contain errors.
