How can I identify which wires are L, N, and PE in an old apartment electrical installation?
In this old installation, L is at the bottom, N is on the side rails, and there is no PE, but you must verify it with a meter because old installations can contain surprises [#16583819][#16583824] A meter is the only reliable way to confirm the conductors in practice [#16583824]
Hello, there is an old electrical installation in my old but my new apartment, I would like to ask you how to distinguish where L, N, PE does not want to bury anything there, but I would like to find out how to distinguish these cables, see the photo below.
I am thinking about replacing and I am interested in electrics, but I do not want to connect something the other way around. The bottom of the fuse is easy to understand, but this top is a bit scary.
The discussion revolves around identifying electrical wires in an old apartment installation, specifically distinguishing between Live (L), Neutral (N), and Protective Earth (PE) wires. Participants emphasize the importance of using a multimeter to verify wire functions, as color coding may not be reliable in older installations. The user expresses a desire to understand the wiring before potentially replacing it, while others caution against DIY electrical work without proper knowledge. The conversation highlights the need for careful handling of electrical components and the risks involved in amateur repairs. AI summary based on the discussion. May contain errors.
