18v screwdriver, can you charge the battery with a laptop adapter?
alankulak1901 12561 9
Can I charge an 18V Einhell Bavaria BAS 18 NiCd screwdriver battery with a laptop adapter?
No, not as a direct substitute for the original charger; this 18V NiCd pack needs about 21V charging voltage, so a typical laptop adapter is usually too low [#16585561] If you use a universal adapter, charging in the 20V range is described as safer, but the pack may not fully charge; 22V is suggested only for the last phase for about 10 minutes, while watching battery temperature [#16585755][#16586084] Direct charging without current limiting is risky because a deeply discharged battery can draw very high current and be damaged [#16585857] One suggested workaround is to put a 12V 10–15W car bulb in series to limit current at the start [#16585993] A proper dedicated charger is still the best solution, for example one built around a MAX712 charger IC [#16585857]
  • #1 16585419
    alankulak1901
    Help: 6
    Rate: 35
    Hello, I have a screwdriver for 18v, and the battery is low, and hence my question, can you charge it with a laptop adapter?
    The screwdriver is: Einhell Bavaria BAS 18
    NI-CD 18V battery
  • #2 16585561
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    No, because you need a 21V power supply to charge this battery. The rated voltage is 18V or 15 cells 1.2V connected in series. The charging voltage of such a single cell is a minimum of 1.4V, which gives just 21V.
  • #3 16585728
    alankulak1901
    Help: 6
    Rate: 35
    teskot wrote:
    you need a power supply with a minimum voltage of 21V
    But the power supply is universal and has voltages from 15v to 24v, there are 21, but 20v and 22v.
  • Safe 20V charging with brief 22V finish
    #4 16585755
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    It will safely charge in the 20V range, although the batteries are not fully charged; in the last phase you can switch to 22V for 10 minutes. Control the battery temperature. The one that burns is usually scrap metal. It can be slightly warm. At the performance of the laptop adapter, charging will take no more than 2 hours. Check the temperature every 10-15 minutes because it is only a partisan Do not treat this solution as a target.
  • #5 16585857
    Freddy
    Help: 1394
    Rate: 2821
    teskot wrote:
    It will safely charge at 20V ...
    It will not be safe, because in the event of a large discharge, very high current will flow that can damage the batteries. A restriction should be installed.
    It's best to build a special charger for example on the popular and cheap MAX712 system.
  • Charging path depends on the screwdriver base design
    #6 16585884
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    I should write: SAFER. But apart from everything else, the question still remains: should charging be done directly from the said power supply or through the "base" in which the battery is inserted and the power supply attached to it? In this stand / footer, and really the charger is usually a current limiting resistor. And since the author asks whether it is possible to charge the battery in question with the laptop adapter, the question arises whether the adapter charger of the original charger has been damaged / lost, or the entire charger or in the given screwdriver model can the battery base be integrated with the power supply? Sure, you can build a charger, but since the author asks the above question, it seems to me that for some reason he found himself in a sub-gate situation.
  • #7 16585902
    alankulak1901
    Help: 6
    Rate: 35
    teskot wrote:
    if the power supply of the original charger has been damaged / lost
    I got a screwdriver from a friend without a charger, it was charged, and I only needed it for a while, and now I need it and it is unloaded. :P
  • #8 16585993
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    It's like having a car bulb or other 12V 10-15W handy, turn it on in series with the charger, so as not to smash the battery with a high charging current at the beginning.
  • #9 16586071
    alankulak1901
    Help: 6
    Rate: 35
    teskot wrote:
    ] turn it on in series with the charger
    At what voltage, 20v or 22v?
  • #10 16586084
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    Invariably, as I wrote - first 20V, let's put 22V after an hour. Keep an eye on the temperature because I don't want to have you and this battery on my conscience.
The discussion revolves around the feasibility of charging an Einhell Bavaria BAS 18 screwdriver's 18V Ni-CD battery using a laptop adapter. Initial responses indicate that a 21V power supply is typically required for safe charging, as the battery consists of 15 cells at 1.2V each. Some participants suggest that charging with a 20V adapter is possible, but caution against potential risks, such as overheating and damage due to high current flow. Recommendations include monitoring battery temperature during charging and using a current-limiting resistor to prevent excessive current. The conversation also touches on the absence of the original charger and the need for a temporary solution.
