Audi A3 8L Front Speakers Replacement: Factory Radio, Door Speaker Options & Upgrade Suggestions
wojtek1231 13023 2
  • #1 16588131
    wojtek1231
    I need to replace the speakers from the front because I have the same factory there.
    For now, the factory radio. Is there any sense to do this? If so, what are the loudspeakers in the door?
    Because at the moment the game is thin and sometimes trembles as it gets worse.
  • #2 16588179
    martinnrw
    Rate: 14
    Hello, what radio do you have? model?
    I suggest to dampen the door and see if the sound will be satisfactory if it is not then the radio and possibly the loudspeakers are separated at distances. Write what you expect and what you are listening to mostly radio cd music genres. You can also try the subwoofer in the A3 8L are cool housing in the left compartment in the trunk - but later.
  • Factory radio power may be too low for front speakers
    #3 16593103
    wojtek1231
    Factory radio Audi A3 8L Front Speakers Replacement: Factory Radio, Door Speaker Options & Upgrade Suggestions
    I do not know how much power it has, etc.
    In addition, these audi are 4-door, which means that there are also speakers in the back of the door. In the boot in the sides of the woofer but not in the box.
    Everything like the factory.
    In general, I would like to do the front itself.
    I just do not know if the radio will pull it.
