Replacing Antenna Amplifier in Telmor ASR Classic LTE Protected Model - Guidance Needed
DawidPL123 5847 10
Can the amplifier in an ASR Classic LTE Protected SAW antenna be replaced, and how do I access it?
Yes, the amplifier can be replaced, but it sits inside the spherical dome and you have to unscrew the plastic carrier from the blue boom, then split that carrier in half to reach it [#16589577] However, this model uses a passive/active bypass amplifier, and that part was said to be difficult to find separately, so Telmor or the manufacturer may need to repair it [#16589577] Before opening the antenna, check whether the fault is really the amplifier: one report said that with power off the antenna still received most multiplexes, which suggests possible overload or interference rather than a dead preamp [#16589577][#16590100] Another suggestion was to try a regulated power supply, since the antenna accepts +5 to +24 V [#16590307]
  • #1 16589349
    DawidPL123
    Please help.
    I have had an ASR classic LTE PROTECTED SAW antenna for a year.
    I have had weaker channel reception for a week, not all multiplexes are working.
    The power supply and other network elements have been checked.
    Is it possible to replace the antenna amplifier in this model?
    I can't find information on how to "get" to the amplifier in the antenna.
    antenna data
    Receiving frequency range MHz 470-790 *
    Gain dB @ MHz 14 @ 470-782
    Gain in the operating band dB 19
    Attenuation out of operating band dB @ MHz 26 @ 800
    Polarization / Horizontal (H)
    Beam width 3dB (horizontal plane) ? (deg) 40
    Radiation ratio - front / rear dB 24
    Noise figure dB ?3.5
    The maximum level of the TV signal at the output
    (DIN) dBuV 100
    Power supply / current consumption V / mA +5 .. + 24/40
    adapted to receive digital terrestrial DVB-T signals,
    has a built-in 470-790MHz band-pass filter,
    can work as passive or active,
    has a very high energy gain, and a built-in ultra-low noise preamplifier,
    aesthetic and durable structure,
    powering the preamplifier with DC voltage in the range of + 5... + 24V.
  • #2 16589577
    _kli_
    Help: 759
    Rate: 1035
    DawidPL123 wrote:
    I have had it for a year ASR classic LTE PROTECTED SAW antenna
    Yes. You have a guarantee, so on the manufacturer's website.
    Disassembly requires unscrewing the plastic carrier from the blue beam. Then this one plastic carrier you need to unscrew it and gently split it in half. Amplifier it is in this spherical dome.
    But your antenna
    DawidPL123 wrote:
    it can work as passive or active
    so it has an amplifier with the so-called by-pass. And I have not met such in trade. For example, when asked about such an amplifier, in the company store I received the answer that the antenna should be returned to the manufacturer for repair. Alternatively, ask directly in Telmor.
    How did you check this power supply? The lit diode does not mean that everything is OK.
  • #3 16589993
    DawidPL123
    The symptoms are that the antenna was working all the time, the reception deteriorated on one day, I checked the installations and everything seemed ok ... except for a small detail.
    When the power supply is turned off, I receive almost all multiplexes (not 100% as it was before the failure), only local MUXes are jammed. When I put the power supply into local networks, there is no ... I will add that so far, the power supply has always been on for a year of using the antenna. I did a test with a different power supply and the same effect: /
  • #4 16590100
    _kli_
    Help: 759
    Rate: 1035
    DawidPL123 wrote:
    in one day the reception deteriorated
    DawidPL123 wrote:
    When the power supply is turned off, I receive almost all multiplexes (not 100% as it was before the failure) only local MUXes are jammed
    Maybe they've recently turned on a BTS in the area and distorts your signal on the amplifier.
  • #5 16590184
  • #6 16590237
    andpol 33
    Help: 513
    Rate: 1145
    Start by substituting the power supply.
  • #7 16590240
  • #8 16590243
    LeDy
    Help: 1989
    Rate: 2930
    New or used power supply? If it were new, you might have distorted. See adjustable power supply.
  • #9 16590280
    DawidPL123
    I did the tests on the power supply used from the old antenna. Shouldn't this antenna be "immune" to BTSs? :) the image cuts a strength and the quality of the signal on the tuner 80-90% without a power supply.
    Try a power supply with regulation?
    _kli_
    Help: 759
    Rate: 1035
    DawidPL123 wrote:
    powering the preamplifier with DC voltage within the range + 5... + 24V
  • #11 16591218
    LeDy
    Help: 1989
    Rate: 2930
    [/ quote]
    What does this quote have to do with it? And in antennas with 12V power supply it can be done. This is my proven method of "matching the amplifier" to local reception conditions.
    I was doing on the power supply used from the old antenna
    And that's the cause of the failure.
✨ The discussion revolves around issues with the Telmor ASR Classic LTE Protected antenna, specifically regarding weak channel reception and the potential need to replace the antenna amplifier. The user reports that after a year of use, reception has deteriorated, and they have checked the power supply and other network elements. Responses suggest that disassembly of the antenna is required to access the amplifier, which is located in a spherical dome. Some users mention that interference from nearby internet antennas or base transceiver stations (BTS) could be affecting signal quality. Recommendations include testing with different power supplies and considering the impact of local installations on reception. The possibility of returning the antenna to the manufacturer for repair is also mentioned.
