Vectra C - Steering wheel with exclamation mark and c1532-05 error
Sivyx 21417 6
  • #1 16590002
    Sivyx
    Help: 19
    Rate: 64
    I've been struggling with the topic for a long time ... In general, support comes. Replaced CIM (because it was broken sas) helped, the traction control went out, directions reflect.
    Only the steering wheel was left with an exclamation mark and error c1532-05. The previous owner replaced the pump and the TRW pump sits with two cables and two end caps. The fluid is, all pins are psyched by contact, in the pump included esp and yrs.
    Is Pompe somehow programming? Is it just how to configure CAN in opcom?
    Does the signal that is missing causing the error c1532, goes from the pump straight to CIM?
  • #2 16590222
    adam7009
    Help: 656
    Rate: 1635
    ... Unsuitable pump installed, this can be corrected with a dedicated diagnostic device.
    The pump is being programmed.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #3 16590565
    seat21
    Help: 151
    Rate: 399
    Programming the pump techem2 will do the trick
  • #4 16590616
    Sivyx
    Help: 19
    Rate: 64
    So opcomem / vaucomem ream will not move the topic?
  • #5 16591691
    Trawik
    Help: 75
    Rate: 442
    I did op comem
  • #6 16592801
    Sivyx
    Help: 19
    Rate: 64
    Ie. did you cancel the c1532-05 error? Could you describe something more or less?
  • #7 16593004
    seat21
    Help: 151
    Rate: 399
    rather, he doubts because a colleague tried the opcom and did not give advice until the tech changed configuration
The discussion revolves around a Vectra C vehicle experiencing a persistent steering wheel exclamation mark and a C1532-05 error after replacing the CIM and pump. Users suggest that the issue may stem from an unsuitable pump installation, which requires programming with a dedicated diagnostic tool. While some users attempted to use Opcom for diagnostics, it appears that programming the pump with Tech2 may be necessary to resolve the error. The conversation highlights the importance of proper configuration and programming of the pump to eliminate the error signal.
