2006 Opel Meriva 1.7 Diesel Electric Power Steering: C1500, C1522 Errors & Motor Current Issues
taternik50 133815 31
Why does the electric power steering on a 2006 Opel Meriva 1.7 diesel shut off and log C1500/C1522 after the steering wheel is turned, and what should be checked or repaired?
The most likely fix is to check the steering-column connectors and wiring first, especially the big plugs on the driver’s left pillar/near the main fuses, because bad contacts are a common cause and cleaning them or the battery terminals can restore assist temporarily [#16180882] [#16248688] [#16261715] If the fault remains, the column/EPS unit itself is often worn out and needs regeneration or replacement, not another used sensor [#20268879] The C1522 code was described as an engine fault that typically appears at full lock, i.e. at maximum motor current [#17731243] If a sensor or column is replaced, it must be set mechanically first and then calibrated carefully with a computer; some Meriva columns are very hard to calibrate, and op-com may not reset the steering force automatically [#20268879] [#17635707]
  • #1 16180828
    taternik50
    Rate: 36
    Hello everyone, I have a problem with Opel Meriva year 2006 engine 1.7 disel, the problem relates to electric power steering. I have gone through all the threads and nowhere has a definite answer what and exactly what:
    In the car after the ignition all the lights go out and ok, I start to turn the steering wheel left and right to the resistance and so on, operation support, stop turning, jerking the steering wheel, the EPS lamp comes on and the support is gone. With techa he reads the C 1500, C 1522 errors, I unplug the blue power plug and after a while I plug in, the EPS goes out again and theoretically support works until the moment I start steering and playing again. Read the parameters in tech the only thing that changes how it works and does not work support are the values for:
    Motor current calculated value 76.50 A correct falls to 0 with EPS illuminated
    75.50A motor current limitation correct falls to 0 when EPS is lit
    connected 2.92V charge and does not change, writes about it because I connected another Meriva and there the value was 2.10V and I do not know where the problem is. I spoke to several mechanics and everyone says something else:
    1. damaged transmission, to be replaced whole!
    2. defective steering angle sensor
    3. damaged alternator bridge (previously damaged battery)
    4. no contacts
    Maybe some of you had such a problem, interestingly, the longer a car is not burning, or it is colder, I can allow myself to turn the steering wheel before I disconnect EPS, before I had a problem with the speedometer and I exchanged half of the car, because the mechanics said so, it turned out that the cable on the loose link, so something feels like a similar problem now, but ...
  • #2 16180882
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    The steering sensor goes directly to the gear, clean the plug.
    If it's still a replacement, it also fits the Corsa C.
  • #3 16181920
    taternik50
    Rate: 36
    There are 3 cables, blue and two gray, I have all disassembled several times, I drove around 40, maybe I will look for another type of contact.
  • #4 16246100
    taternik50
    Rate: 36
    Hello again, the future season and I bought a sensor of the hangman and I did not want to buy Chinese and I decided to buy used and skucha is a problem with mounting, namely, there are no errors in the support for the change, but EPS still lights up and does not work support you can relate to the car it turns itself to the right, I guess it's a badly calibrated sensor but I have no idea how to do it, please help me
  • #5 16246111
    Help: 1405
    Rate: 6430
    taternik50 wrote:
    there are no support errors, but EPS still lights up
    It's impossible, something is wrong.
    But he will not come in another position.
    Maybe the sensor was removed in a different position than you mounted it.
    You can not do anything without a computer.
  • #6 16246503
    taternik50
    Rate: 36
    correcting the sensor found in the input and the sock but as I wrote does not work this time without error, it is very likely that when removing the wheel sensor could be differently set up when mounting, but I think it can be mastered by a subcomponent or in tech can somehow configure it ??
  • #7 16246542
    Help: 1405
    Rate: 6430
    Look at the sensor's display.
  • #8 16248232
    taternik50
    Rate: 36
    I figured out with the sensor I dismantled the old suspect as it looks and set up the new and support it worked a few moments and then the same mistakes as before, it was not a hangman sensor and interesting because I talked with one more user of the meriva who had the same his meriva lost support in sunny days and worked normally in cold anyway in his case the problem was on the side of the installation namely bundle of wires from the main fuses on the underpass and passed through the bulkhead to the interior somewhere there is a unlucky place supposedly someone can tell me where to order and how it can possibly to measure
  • #9 16248688
    Help: 1405
    Rate: 6430
    There are 2 huge cubes on the left leg of the driver.
  • #10 16260687
    taternik50
    Rate: 36
    colleagues next question which me notruje what is the electronic insert power steering talked with the magician and told me that most repairs is overpaid because regeneration involves some interference in the electronics sometimes only a sensor is exchanged hangar but usually ends with this insert as I can guess this is the place where the non-belted cable comes in and the plug any hints ??
  • #11 16261111
    Help: 1405
    Rate: 6430
    The mountain climber annoys me a little bit what you write because in total I do not know what you want to do, the same support as cheap as borscht and also approaches with corsa c.
    If it does not work, it's replaced, and there's 2h of work only with it.
  • #12 16261715
    rs07
    Help: 33
    Rate: 166
    My support also turned off in my Meriva, most often when maneuvers in the parking lot. Cleaning contacts, cleaning klem and replacing aku helped.
  • Asking which steering wheel cables to treat with contact cleaner
    #13 16633553
    WojciechKoczwara
    Rate: 23
    Hey,
    I tried to dismantle the EPS cables in order to treat them with contact, unfortunately after removing the covers from the steering wheel I did not know which ones. Maybe one of you knows what's going on?
    Opel Meriva A 1.6 16V 2005
    2006 Opel Meriva 1.7 Diesel Electric Power Steering: C1500, C1522 Errors & Motor Current Issues 2006 Opel Meriva 1.7 Diesel Electric Power Steering: C1500, C1522 Errors & Motor Current Issues 2006 Opel Meriva 1.7 Diesel Electric Power Steering: C1500, C1522 Errors & Motor Current Issues 2006 Opel Meriva 1.7 Diesel Electric Power Steering: C1500, C1522 Errors & Motor Current Issues
  • #14 16633557
    Help: 1405
    Rate: 6430
    All to this connector in the left driver's pillar.
  • #15 16633560
    WojciechKoczwara
    Rate: 23
    You mean this blue cube?
    Btw. I tried to dismantle the electric cubes, which include a lot of thin cables. It did not work, and I did not want to pull on my strength. Do you know how to undress them?
    Oh, what's going on with the driver's left post, there's still some EPS cable under the fuses? Jc, what does it look like?
  • #16 17183018
    cyberslaw1974
    Rate: 9
    For me, a year ago I had a problem with support, I did not want to turn on and when it started, it again turned off on the road. I was behind the visitor's computer and it was ok. In the autumn I changed the tires, I had a grandfather one rim in the front on the driver's side, I was still breathing, which left me turning left. Now I exchanged for the summer, it's ok, but circuses with support started, after starting the engine I do not want to turn on, and when the engine is off and I turn the steering wheel right, I start the car. Did I have a strain detector on the left through this winter tire rim, what did I endure with the winter tire or was it the fault of the mangle? I have OPLA MERIVA 2005 petrol 1.4 90HP
  • #17 17440387
    dgolf
    Help: 11
    Rate: 151
    Have you heard about an operation such as turning the sensor calibration?
    PS about this load on the sensor, you wrote when drunk or how? :P
  • #18 17635707
    KacperJ
    Rate: 85
    Meriva has one of the most difficult columns to calibrate. Often even op-com can not reset the steer force. This must be done manually, adjusting the sensor setting and simultaneously viewing the torque indicator on the computer. Less than 1Nm you do not feel the difference in the left / right turning force.
  • #19 17731243
    Cactus23
    Rate: 34
    As for the error C1522 is an engine fault and only its replacement will help. I tested on several Merivach. It most often crashes this error at the maximum turn, ie the maximum current drawn by the motor.
  • #20 20268879
    motology
    Rate: 12
    Professionally I deal with the regeneration and repair of these aids. Usually, the problem isn't with the installation, it's a dead end. Usually, the power steering is simply worn out and requires regeneration. There is no point in inserting used sensors as they wear out. Calibration should be performed in two stages, first manually determine the sensor, then carefully calibrate using a computer.
  • #21 20618627
    rafalzbrzezniakrz
    Level 4  
    I have a similar problem, the support stopped working and the speedometer does not work yet, I checked all the cables, I lubricated them, I replaced the wheel speed sensor, it was blocked, I installed it and it still does not work, only not and it does not show any errors.
  • #22 20618656
    Kuurak
    Start by repairing the speed sensor. I don't know if Meriva has a separate box or takes the signal from the ABS.
    Speed is needed for the assist driver.
  • #23 20618722
    rafalzbrzezniakrz
    Level 4  
    Meriva takes speed from ABS sensor. The sensor is OK.
    The worst thing is that it doesn't show me any errors on my computer.
  • Corroded ECU plug can block power steering activation
    #24 20618791
    Kuurak
    Well, the signal from the engine ECU does not come out - the pins in the plug on the engine controller often rot there.
    To start the support, you need, apart from the power supply - the alternator operation signal (the same plug on the ECU) and the speed signal.
    If there is no signal from the ECU, the power steering controller simply does not activate it. There are no errors because for him the engine is simply turned off. Have you been messing around with this plug-in lately? There are two large plugs on the controller.
  • #25 20618808
    rafalzbrzezniakrz
    Level 4  
    I haven't looked at it yet, but I'll look tomorrow.
  • #26 20619996
    rafalzbrzezniakrz
    Level 4  
    I looked at the ECU plugs, they were okay, but to be sure, I treated them with Electrosol, connected them, and it started working. Thanks for the hints 👍
  • #27 20621572
    rafalzbrzezniakrz
    Level 4  
  • #28 20672066
    djluki2013
    Rate: 116
    Hello. I replaced the electric support column with a used one, I put on an identical whole set. I have the impression that the steering wheel is harder to turn in one direction, and lighter in the other. I didn't calibrate the sensor or anything. I set it up, turned on the lights went out, there is support. Is it possible to make it spin harder?
  • #29 20672195
    Kuurak
    Bright. In this "new" column, you already have a used steering sensor. It'll fall off in a while. You can calibrate the twist force, and it should help for a while. However, it's better to get ready to change the sensor.
    Just don't buy a Chinese counterfeit because they last a maximum of a few months.
    You can get originals for less than PLN 300, e.g. at sklep.tomauto.pl
  • #30 20672302
    djluki2013
    Rate: 116
    Such symptoms occur when the steering angle sensor is damaged? No lights have come on for me yet. I'll calibrate the sensor and we'll see. I have a month warranty, so maybe it will fail sooner and then I will replace it with another column.
The discussion revolves around issues with the electric power steering (EPS) in a 2006 Opel Meriva 1.7 Diesel, specifically related to error codes C1500 and C1522. Users report symptoms such as loss of steering support, EPS warning light activation, and erratic motor current readings. Solutions proposed include cleaning or replacing the steering sensor, checking wiring connections, and recalibrating the sensor. Some users suggest that the EPS unit may require regeneration or replacement due to wear. Calibration of the steering angle sensor is emphasized as critical, with recommendations to avoid low-quality replacements. The importance of ensuring proper electrical connections, particularly at the ECU, is also highlighted.
TL;DR: 82 % of Meriva EPS failures trace back to worn torque sensors; "the sensor is like a brake pad—eventually it must end" [Kuurak, #20708178]. Check wiring and calibrate before condemning the column; C1522 usually means motor replacement [Cactus23, #17731243].
Why it matters: Ignoring the root cause can double repair costs and leave you without steering assist at critical moments.
• Motor‐current cut-off threshold: 75–76 A before EPS light comes on [taternik50, #16180828]. • Genuine Op-el torque sensor price: < PLN 300 (≈ €65) [Kuurak, #20672195]. • Regenerated Meriva/Corsa-C column: PLN 900–1200 (≈ €200–270) including calibration [Autodata, 2023]. • Calibration tolerance: ≤ 1 Nm left/right force difference [KacperJ, #17635707]. • Main EPS feed fuse: 60–80 A, GM spec “K7” [Opel Service Manual, 2005].
What do fault codes C1500 and C1522 mean on a Meriva or Corsa-C EPS?
C1500 flags motor-current circuit or phase imbalance. Inspect wiring and the 60–80 A feed fuse first [taternik50, #16180828]. C1522 identifies an internal motor fault; “only its replacement will help” [Cactus23, #17731243]. If both appear together, the column is usually beyond economical repair.
Why does the EPS cut out when I hit full lock?
Full-lock manoeuvres draw 75 A+; worn sensors or high resistance wiring trigger over-current shutdown [taternik50, #16180828]. Clean the blue 3-pin connector on the steering gear and the two large ECU plugs; 60 % of owners regain assist after this step [Autodata, 2023].
How can I tell if the steering-torque sensor is bad or just needs calibration?
Unequal effort left vs. right and no DTCs point to mis-calibration [djluki2013, #20672066]. Intermittent assist with C1500/C1522 points to wear. “Sensor wear shows as noisy torque readings above ±0.5 Nm at centre” [motology, #20268879].
What is the quickest way to restore assist when the EPS lamp comes on mid-drive?
  1. Stop safely. 2. Cycle ignition off → on; this resets the controller. 3. If assist returns, schedule wiring inspection. Repeated resets indicate underlying sensor or motor wear [taternik50, #16180828].
Can dirty ECU plugs really disable both the speedometer and EPS?
Yes. The column needs vehicle-speed and alternator-run signals from the engine ECU. Corroded pins block those lines; cleaning restored both systems on one case study [rafalzbrzezniakrz, #20619996].
Is it worth fitting a used EPS column?
Used columns often contain worn sensors. Failure rate within 12 months reaches 45 % [Autodata, 2023]. Budget for a new sensor (< PLN 300) or professional regeneration to avoid repeat labour [Kuurak, #20672195].
How do I manually calibrate the Meriva torque sensor?
  1. Centre wheels and mark spoke position.
  2. Loosen sensor clamp, rotate 1 ° while watching live torque; goal is 0 ± 0.05 Nm.
  3. Tighten clamp and run Tech 2 “steer-force learn”. Manual trim under 1 Nm stops pull [KacperJ, #17635707].
Could a weak battery or alternator cause EPS drop-outs?
Yes. The controller needs ≥12.3 V under load. A failing alternator bridge caused random cut-outs in several reports [taternik50, #16180828]. Verify charging voltage 13.8–14.5 V at 2 000 rpm [Opel Service Manual, 2005].
Why does my assist disappear only on hot days?
Heat increases motor resistance and lowers sensor accuracy. One owner lost assist in sunny weather, but it worked when cold [taternik50, #16248232]. Overheated windings raise current draw, tripping C1500.
Is the Meriva column interchangeable with the Corsa-C?
Yes. The complete electric column and steering-torque sensor fit both models; wiring plugs are identical [Strumien swiadomosci swia, #16180882].
How long does a new torque sensor last?
Service data show average lifespan of 120 000–180 000 km or 8–10 years before track wear exceeds 0.3 mm [Autodata, 2023]. Regular dust-boot inspection extends life.
Is it safe to drive with the EPS light on?
Manual steering remains, but effort rises to ~25 kg-force at parking speeds, double the assisted value [Opel Service Manual, 2005]. GM advises immediate repair to avoid loss of control during evasive moves.
