Vectra C: Internal Joint Issue - Diagnosing Steering Wheel Vibrations (110-140km/h) & Replacement
szczupx 10224 9
How can I diagnose whether an inner CV joint is causing steering wheel and body vibrations at 110–140 km/h, and which side should be replaced?
Check the wheels/rims first, because vibrations that appear only in a certain speed range can come from rim runout or ovality even when tire balancing looks fine; swap the front and rear wheels and inspect the rims carefully [#16636363] To test the inner CV joint, lift one side, put the drivetrain in gear (1 or R), and force the wheel forward and backward; a loud metallic knock from the joint housing and noticeable front-to-back play point to a worn inner joint [#16636315] Repeat the same test on the other side to compare play and noise [#16636315] Inner joints usually complain under acceleration load, so if needed, swap the left and right half-shafts to see whether the symptom changes sides [#20059809] If the joint test is unclear, also inspect the gearbox-side mounts/cushions and brake discs/calipers, since similar vibrations can come from those parts [#20059809][#20059781][#36538]
  • #1 16636188
    szczupx
    Level 19  
    Help: 29
    Rate: 94
    Problem: disappearing and appearing body and steering wheel vibrations, most strongly felt above 110km / h to 140km / h
    Tires checked and balanced, the same is the case with another set. In addition, if the cause were tires rather vibrations would occur all the time. There is nothing worrying about suspension. Geometry also set.
    It is possible that this is an internal joint, the question is how to determine that it really needs to be replaced? And if so, how to determine which one?
    Automatic gearbox.
  • #2 16636315
  • #3 16636325
    szczupx
    Level 19  
    Help: 29
    Rate: 94
    szpoak wrote:
    in gear (1 or R)
    this machine ...
  • #4 16636363
    g107r
    Help: 811
    Rate: 993
    Do you feel these vibrations at different speeds or only in the range 110-140km / h?
    A set of tires? Did someone check the rims? Have you changed the front wheels for the rear?
    I had rims, eighth, and oval. One was felt at about 80-90, the other above 110km / h.
    It turned out by accident, the gummy man had trouble balancing the wheels, which did the trick, but this one told me about the rims .
  • #5 16636472
  • #6 16636538
    Freddy
    Help: 1394
    Rate: 2821
    I had the same situation in Astra and it was a warped brake disc.
  • #7 20054292
    mientus1987
    Hello, was the problem solved?
    What was the reason?
    I have been struggling with the same problem for a year now and no mechanic can find out what is the cause.
    The suspension is proven to be stiff and functional.
    Tires changed with rims.
    The problem probably began after changing the steering gear, although the mechanics say that this one is in working order.
  • #8 20059781
    kredens007
    Rate: 20
    Start by checking the brake discs, is the brake caliper working as it should? Not holding?
    If the brake system is ok, it may be an internal joint, it works well on a raised car, you should see something.
    Possibly, the converter may fail.
  • #9 20059809
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    The inner hinge is made on one side. Acceleration loads. You can change the right one with the left one, there are no such forces when braking with the engine. Mostly as internal joints usury is telepiece when accelerating. As for vibrations, the cushions on the gearbox side under the engine, the rims with the wheels on the lift, twist or beating. Possibly replace the wheels.
  • #10 20059975
    mientus1987
    Discs, calipers checked and everything is ok, so either joints / half axles or a mangle (it was regenerated right after buying the car) The worst thing is that for a year and a half, nothing has changed but these vibrations drive you crazy (they are only between 110 and 140 km / h)
The discussion revolves around diagnosing intermittent body and steering wheel vibrations in a Vectra C, particularly noticeable at speeds between 110-140 km/h. Users suggest various diagnostic methods, including checking for play in the internal joints by moving the wheel while the vehicle is in gear, and inspecting brake discs and calipers for issues. Some users experienced similar problems linked to warped rims or brake components. The possibility of internal joint failure is highlighted, with recommendations to swap joints from one side to the other for testing. The issue persists despite thorough checks on tires, suspension, and geometry, indicating a need for further investigation into the internal components or potential gearbox issues.
