Vectra C - Dismantling and Repairing TRW Power Steering Pump on Opel Vectra C
Majeran123 20844 4
  • #1 16926723
    Majeran123
    Rate: 77
    Hello, forum members.
    I am repairing the TRW support pump. Vectra C - Dismantling and Repairing TRW Power Steering Pump on Opel Vectra C Vectra C - Dismantling and Repairing TRW Power Steering Pump on Opel Vectra C Vectra C - Dismantling and Repairing TRW Power Steering Pump on Opel Vectra C
    Have you repaired something like that and you know how to undress it?
    If not how? Welt?
    Thank you in advance for your answer :)
  • #2 16926764
    szymitsu21
    Help: 342
    Rate: 1292
    And what's the problem? what happened?
    Because it is often not very cost-effective to repair (in my opinion)
  • #3 16926871
    Majeran123
    Rate: 77
    Failed assistance message, 2 permanent faults in assistance, non-active assistance. Everything caused by moisture in the controller. I dismantled the pump, engine and it is the last element to remove and clean the plate. My friend's colleague and I try to embrace it cheaply.
  • #4 16926912
    szymitsu21
    Help: 342
    Rate: 1292
    Recently in the Zafira that I was doing, it was enough to bask hot and bangla :)
  • #5 16926924
    Majeran123
    Rate: 77
    After dismantling the plastic with the cubes, you can see that there was water, until it flew. Through the holes you can see that February is green. that's why I want to download it :)
