[Solved] Philips 32PFL5007K / 12 - I am looking for a diagram of the DPS-98 EP power supp
multi72 15303 5
  • #1 16590353
    multi72
    I am looking for a diagram of the DPS -98EP power supply
    motherboard Q552.4E
    I found a lot of schematics for this TV, but there is no schematic of this power supply in any of them
  • #2 16590525
    mirex
    Help: 1950
    Rate: 1990
    There is no. And already. ;)
    Create a topic in the service department and describe your problem with this power supply in detail. There will be similar solutions.
  • PSU and backlight controller part identification
    #3 16593151
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    PHILIPS LED, Model: 32PFL5507T / 60
    Chassis: Q552.4E LA
    Panel: LTA320HW02 (code: 395)
    T-CON: PH_120PSQBC4LV1.0 LPF12B0
    LED driver (backlight): integrated into PSU
    - LED driver: DDA015
    - MOSFET LED: D4NK60Z
    Power Supply (PSU): DPS-98EP A (2722 171 90579)
    - PWM Power: DDA010 (Standby) / IC901 (DDA010)
    * DDA010 - 1pin ZC (Zero Crossing) = ICE2QRxx65 / 80x
    - ST9S101, ICE2QS02G (PWM)
    The rest of the systems described on the forum, the Search option
    • ICE2QS02G.rar (387 KB) You must be logged in to download this attachment.
    • DDA010.rar (618.51 KB) You must be logged in to download this attachment.
    • IN1M101.rar (674.3 KB) You must be logged in to download this attachment.
  • #4 16593194
    multi72
    I have a damaged main power supply. Damaged IC 601, R610, R 611, R605, R607, R609 All components unreadable
    lisek
    Help: 6352
    Rate: 6883
    IC901 = DDA010 / * = (ICE2QR0665)
    IC902 = S101 (ST9S101-T6G) = (IN1M101-T6G) SOT-26 Supervisor
    IC601 = DDA015
    Look at the diagram of the DPS-140 [/ u], it is in the network / forum> but no denominations of RC elements
    - or on
    - or DPS-130PP
    IC601 DDA014 Link
    IC801 NCP1608B
    IC902 S101
    IC901 DDA010 (DIP8)
    ____________________
    There was a time
    Or p. 89 from SM under q552.2
    Link
    With the Delta PSU DPS-135JP A.
    - DDA014 (* SSC9502S analog).
    • dps-140sp_no nom.pdf (136.07 KB) You must be logged in to download this attachment.
  • #6 16595200
    multi72
    Thank you for all the help, the power supply is almost ready. I have one more request, I have a second-hand TV, someone has soldered the NVM memory from this TV. There is no picture in the clean. I'm looking for a bin. From what I can see 32 inches were not very popular with this model
