Seeking Schematic for Philips 42PFL6158K/12 Power Supply (272217190775)
reiki76 14337 5
  • #1 16461198
    reiki76
    Mark:P HILIPS
    Model:42PFL6158K/12
    Chassis (main board, components):P OWER SUPPLY SCHEMATIC
    More informations: POWER SUPPLY 272217190775
    please i need this schematic
    lisek
    Service technician RTV
    Help: 6344
    Rate: 6872
    Power Supply (PSU): FSP140-4FS01 , 2722 171 90775 Rev 00 (272217190775)
    - PWM Power: FSB117H (Standby 8pin),
    - FAN7930 (PFC),
    - SSC9522S (PWM resonant)
    FSB117H(U501), FAN7930C(U601), SSC9522S(U101), BD9479FV(U901)
    LED driver (backlight): integrated into PSU
    - PWM LED driver: BD9479FV
    Has no Service Manual (SM), or schematic.
    Only after there are SM based on the same IC
    Model TV it is chassis QFU1.2E LA
    40PFL8008K, 40PFL8008S
    42PFL6008H, 42PFL6008K, 42PFL6008S, 42PFL6158K , 42PFL6158S, 42PFL6188K, 42PFL6188S, 42PFL6198K, 42PFL6678K, 42PFL6678S, 42PFL7008H, 42PFL7008K, 42PFL7008S, 42PFL7008T, 42PFL7108H, 42PFL7108K, 42PFL7108S, 42PFL7108T 46PDL8908S, 46PFL8008K
    • FSB117H.rar (735.19 KB) You must be logged in to download this attachment.
  • #3 16461784
    reiki76
    Good morning, my 42pfl6158k / 12 TV does not turn on, I'm trying to check if it's a power supply or main board problem. The red standby LED does not light. Could you help me with what items to check or change?
    lisek
    Help: 6344
    Rate: 6872
    Few time ago (07 Gru 2016 11:01) on this forum wrote Link
    All times led stby. No indicates ?
    ____________________
    TV after switching on does not respond to the remote nor the keyboard, is not light LED stby.
    After approx. a minute, the led stby. indicates errors 2 short flashes, pause, 2 short flashes.
    The chassis of this TV is QFU 1.2 E LA
    And last Link
    SM chassis QFU1.2E LA (no schematic PSU) Link
    • AN-9752.pdf (1.01 MB) You must be logged in to download this attachment.
    • AN-8024.pdf (578.5 KB) You must be logged in to download this attachment.
  • #5 16462014
    reiki76
    Sometimes if you press the remote the led flashing few times
  • #6 18920459
    beydere45
    42PFL7108k/12 anakrt problem. Pleşe full firmvare.. or mainboard bios dump download?
