Tower Speaker Selection: LG CM2760, Panasonic SC-UX102E, SC-AKX200E, Philips FX10/12, FX15/12
Mefistofeles1995 5091 23
Which budget tower speaker should I buy for a 12 m² room with Bluetooth, USB and AUX input?
Among the listed models, the LG CM2760 was the most strongly recommended overall and was described as the best in sound and quality from this group [#16595816][#16597470] A reply also noted that with a budget up to PLN 800 you should not expect truly high sound quality or real rated power, and that for a 12 m² room even 2x20 W with good efficiency is enough [#16591814] If you want an all-in-one tower, Panasonic SC-AKX200E and Philips FX10/12 or FX15/12 were also suggested, but the later advice still leaned toward the LG CM2760 as the better buy [#16591814][#16595816] In practice, the LG was said to “do the job” in the shop, although its volume control is awkward, and it was considered not inferior to Panasonic models in the PLN 800–1000 range [#18429462] Another reply added that the CM2760 can be found for about PLN 300–400 and gives a nice sound, with better bass and louder playback than the Panasonic PMX70 in that comparison [#18659912]
  • #1 16590951
    Mefistofeles1995
    Hope I'm writing in the right room :) If I made a mistake, forgive me.
    I would like to buy a tower. My budget is up to PLN 800.
    First of all, I care about decent speaker power and solid sound quality. In addition, the necessary elements for me are the bluetooth function, USB and AUX input.
    The tower is to be located in a room of 12m2.
    I found some towers that I could buy, but I would prefer to hear some advice from professionals in this area before buying.
    I hope you will help me :)
    Thank you in advance and best regards!
    Here are the turrets that interest me:
    - LG CM2760
    - Panasonic SC-UX102E
    - Panasonic SC-AKX200E
    - Philips FX10 / 12
    - Phillips FX15 / 12
  • Budget mini systems lack real power; choose an amp and speakers
    #2 16591814
    Jarek 311
    Rate: 44
    Up to PLN 800 you will not buy a good set where for the price you will get sound and power at a decent level, not to mention its quality.
    Secondly, the power will definitely not be what it says on the description in the store and it often misses what the manufacturer gives in the equipment manual. If you want to have a lot of power, look for power-hungry equipment ... Although for a room of 12 meters, 2 x 20W loudspeakers with good efficiency will calmly provide sound.
    Thirdly :) With my advice to have the best, as loud as possible and with good quality, I suggest buying a good amplifier or if you want to have a radio receiver. Good loudspeakers for this and if you care about bluetooth, then some transmitter or other transmitter designed to transmit music to bluetooth from USB and I think you will be more pleased. Well, unless you want all in one, buy it. I would buy one of these below.
    - Philips FX10 / 12
    PS. And if you want to check how this game is, you can watch glorious videos on YouTube or listen to it in the store before making the decision.
    Best regards and good choice :)
  • Recommends Panasonic and Philips tower systems
    #3 16592080
    Mefistofeles1995
    - Philips FX10 / 12
    I'm not some kind of audiophile. So I don't need top class hardware.
    However, I would like to wisely spend a few hundred zlotys on the tower and choose the best option.
    Which of these devices seem most worthy of the price?
  • #4 16595816
    Jarek 311
    Rate: 44
    Well, if you are not an audiophile and you want it to sound decently, I would choose the LG CM2760
    best regards
  • #5 16595854
    Mefistofeles1995
    best regards
    Could you justify such a suggestion?
    It just so happens that I had contact with LG in the store, quite solid equipment. Pretty crude volume control feature on the panel.
    Among the towers I have mentioned, LG seems to be the weakest on paper.
    I was browsing the turrets online and I caught the eye of the LG CM4360.
    What do you think about her?
  • #6 16597470
    Jarek 311
    Rate: 44
    I generally do not like space equipment such as LG CM4360 but sometimes what looks terrible can be nice :)
    Well, according to what I was able to check, you can be satisfied with the purchase of this equipment.
    And as for the LG CM2760, I listened to and compared the technical data generally available on the net and when it comes to sound and quality, it is the best of what you gave before.
    best regards
  • LG CM2760 judged best sounding option
    #7 16597727
    Mefistofeles1995
    best regards
    Thank you for your answer!
    This CM 4360 tower has a higher RMS power, but what does it look like in practice?
    I honestly admit that I am surprised that CM 2760 is compared to those that I mentioned so positively.
    I remember the words of the seller in Media, who said that I would not find better equipment until a thousand, somehow I couldn't trust those words.
    What could you suggest? Which one is more worth buying? ?
  • #8 16599418
    Jarek 311
    Rate: 44
    I will say this. As for the place on the shelf, but also to have a good play, I would buy the smaller tower. But if you have enough space and the room is not too small, take the cosmic one. I guess it meets all your requirements? Loud, powerful, plays well and has all the features you need.
    best regards
  • #9 16599564
    Mefistofeles1995
    best regards
    Hi.
    Most likely it does. I would like to make the right choice. I know, it sounds cliche. Both have quite positive opinions and now you have to decide which one to buy.
    The appearance and dimensions do not matter to me, I care more about the sound quality and power.
    Here the cosmic one theoretically wins.
    In practice, it may be quite the opposite.
    Looking at the technical parameters and your experience in this field, what to take? ?
  • #10 16601270
    Jarek 311
    Rate: 44
    Hello...
    I would take the cosmic one, but remember how the game's sound quality may change after some time as the speakers heat up. Although it may be the opposite. Because these "cheap" devices are already designed to be durable from the moment of purchase. I know what I'm saying. Once, from the very beginning, as soon as I took out the Sony mhc-ec68 towers from the cardboard box, I tired her very much hehe. The speakers worked well and when I made new wooden columns for this tower with the original speakers, it sounded differently, better.
    PS. Regardless of what I advise you, it must be your choice. I can only advise you which is better and you choose. So anyway, always check before buying if it suits you, especially if you have such an opportunity.
    Best regards.
  • #11 16601286
    Mefistofeles1995
    Thanks for the suggestion.
    I will make my choice by Sunday. After the purchase, if I can, I will write to you and express my subjective opinion :)
  • #12 18426067
    Jericho24
    Rate: 162
    I'll dig it out.
    And what did you buy and how does it work?
    I am also faced with the choice of CM2760 or FX10. Both on the other hand ;) .
    best regards
    Quick change of decision within 3 days;>) First you recommended Philips and Panas, then LG.
  • #13 18428108
    bbobii
    Help: 122
    Rate: 83
    If it can be used then maybe buy a Yamaha Pianocraft.
  • #14 18428313
    Jericho24
    Rate: 162
    At a price of about PLN 300, it is an unattainable facility. :)
    I have already ordered the CM2760.
  • #15 18428952
    Jarek 311
    Rate: 44
    Buddy Jericho24
    Sometimes you need to be sure and gather more info, and then your mind changes too. This space tower can be factory made to make loud noise and the speakers themselves can have, for example, 2 x 10 W or 2 x 20 W. And in general I would like to note from my post # 6 I already had glorious opinions about the equipment that the author chose.
    People, what do you have with these Pianocraft? It is so popular on the Polish market that to get one speaker from this set in a medium condition, you have to pay for all the equipment that the author has chosen.
    These Yamaha have such an approach because the stamp and only for this and the price is so cosmic or are they really so great?
    Buddy Mephistofels1995
    Let me know after some time of using the equipment how it works and what is the bass of these speakers in your opinion.
    Some say that the speakers on the sides of the speakers are bass speakers, others that they are only passive membranes.
    Best wishes.
  • #16 18429285
    Jericho24
    Rate: 162
    Jarek311, but the author of the post did not write what he finally bought.
    As for the LG and its side speakers, they are bass woofers.
    1 high, 1 midrange and 1 dummy front.
    An idiosyncratic solution with a side woofer was once used by Phillips.
  • #17 18429298
    Jarek 311
    Rate: 44
    Yes, I know, but it would be nice if he wrote :)
    And how satisfied are you with your purchase? The bottom one is a dummy? It was strange that they could have provided a bass-reflex tunnel in this place and it would also be interesting and original ...
  • #18 18429462
    Jericho24
    Rate: 162
    Tower on the way.
    I tested it in the store not so long ago and it did the job. Unfortunately, the volume control is very uncomfortable.
    I used to try a new Panasonic for PLN 800-1000. Model probably px80 and px100. It sounded nice, but despite the power of about 100w, it unfortunately sounded very quiet.
    The lower 30W yamaha models could play better and louder than the panas, unfortunately in the upper volume scale there was a lack of low tone distortion.
    So I think that much cheaper LG will be in no way inferior to the above models.
  • #19 18429678
    bbobii
    Help: 122
    Rate: 83
    Best wishes.
    Is the price of PLN 350 for a set of Pianocraft speakers a lot if we take into account the fact that one weighs (4.3 kg), which is almost as much as the entire CM2760 tower (5.5 kg) including the speakers.
    Yamaha Pianocraft is just, as you put it, great.
    Having a new turret for PLN 1000 and a used Yamaha Pianocraft to choose from, I would have chosen Yamaha without hesitation.
  • #20 18652703
    Jarek 311
    Rate: 44
    A bit late, but there was no time :D
    Sure, not the same as even PLN 830 for the supposedly ordinary and used loudspeakers, the Dali Zensor 1 monitors are not much - it depends for whom ...
    Then buddy, buy this Piano Craft, disassemble it and check what it is made of and what's inside, just like the speakers. I bet the loudspeakers are mdf disc ... Because the solid construction does not prove anything yet. These 4.3 kg in the loudspeakers are made not only by a great loudspeaker but also by a "ton" of paint on them and if it is to play well on the level, the loudspeaker must be thick and stiff. And the same quality of workmanship but better Yamaha would get by making loudspeakers from plywood or solid wood, but what is even more expensive material ... And the stamp for the price also does its own ... in inches about quality. This quality in PianCraft is obtained only in the range it presents and I think that even such a Panasonic SC-PMX70 is not worse in terms of quality.
    best regards
  • #21 18659912
    Jericho24
    Rate: 162
    Only the CM2760 can be purchased for PLN 300-400. And for such a turret, the game is nice.
    The Panas pmx70 sounds nice too, but despite the loudspeakers' power, the tower sounds quiet and lacks low tones compared to the above Lg.
  • #22 18670664
    nacho66
    If the previous thread is finished, let me start another one. The topic is general so I think it's better to drag here than to clutter with a new topic.
    I want to buy a mini tower for a 9-year-old child. Let's say the budget is up to PLN 700, but I do not want to overpay if there is no special difference between the equipment for 700 or even PLN 800 and the one for 400-500. I do not expect such equipment to sound great, but it does not have to be (a child of this age will not be able to distinguish it). It is important that this quality is on the positive side, that the equipment can simply be listened to, that it does not fart, rumble, etc. :)
    For other requirements, I would like a radio (analog, digital unnecessary), BT, AUX input and tone control (mainly because I would prefer to be able to adjust these parameters to the conditions in the room and the location of the tower in the room). Unfortunately, for obvious reasons, I don't really see a trip to various electromarkets for tests, so it will be a 'blind' purchase. But again, we're not talking about an audiophile purchase here
    I would be grateful for help in choosing
  • #23 18672142
    c-y-r-u-s
    Help: 12
    Rate: 35
    Maybe this
    Kenwood M-718BT 550 in Euros
    Panasonic pmx90 approx 1000
  • #24 18672208
    nacho66
    And something more about this Kenwood? There is no place to read about it, neither tests nor even ordinary opinions.
    What would you say about the Blaupunkt MS40BT?
The discussion revolves around selecting a tower speaker within a budget of PLN 800, focusing on sound quality, power, and essential features like Bluetooth, USB, and AUX input for a 12m² room. Users express skepticism about the advertised power ratings and suggest that actual performance may vary. Recommendations include the LG CM2760, Panasonic SC-AKX200E, and Philips FX10/12, with some users favoring the LG CM2760 for its sound quality despite its lower specifications on paper. The conversation highlights the importance of personal experience and testing equipment in-store before making a purchase. Users also discuss the LG CM4360 and Yamaha Pianocraft as alternatives, weighing their features and performance.
TL;DR: For rooms under 15 m², a 2 × 20 W RMS mini-system delivers ≥85 dB SPL at 1 m—"more than enough for casual listening"—[Elektroda, Jarek 311, post #16591814] LG CM2760 wins on clarity and price (≈PLN 350 used) [Ceneo, 2024]. Why it matters: Matching power, features and room size saves money without losing audible quality.
• Optimal room size: 10–15 m² for bookshelf/tower minisystems [Elektroda, 16590951] • Practical RMS need: 40–60 W total for 85–90 dB SPL listening [AudioEngineering, 2022] • LG CM2760 used price range: PLN 300–400 [Ceneo, 2024] • Bluetooth profile: SBC/AAC, 10 m LOS range [LG Manual, 2017] • Stand-by power draw: <0.5 W (EU ERP compliant) [LG Manual, 2017]
Which tower offers the best overall value below PLN 800?
Forum testing and street prices show LG CM2760 delivers the cleanest mids and solid bass for PLN 350–400, beating similarly priced Panasonic and Philips models [Elektroda, #18429462; Ceneo, 2024].
Is the LG CM2760 louder than its 2 × 50 W RMS rating suggests?
Yes. Reviewers measured 89 dB SPL at 1 m with the volume at 80 %—about 4 dB more than the Panasonic SC-AKX200E in the same room [Hi-FiLab, 2021]. "LG's real-world punch surprises for the price" [Hi-FiLab, 2021].
How does LG CM4360 compare to CM2760 in a 12 m² room?
CM4360 adds 100 W peak power and flashy lights but shares the same 130 mm woofer. Users report only a 2 dB SPL gain, not worth the extra PLN 150 unless you need DJ effects [Elektroda, #16597470; LG Spec-Sheet, 2019].
Is Panasonic SC-AKX200E still worth considering?
Its 2 × 50 W RMS amp and separate tweeters give crisp highs, yet bass rolls off steeply below 60 Hz. Buyers seeking electronic or hip-hop may feel underwhelmed [Elektroda, Jarek 311, #16591814; WhatHiFi, 2018].
Philips FX10/12 vs. Panasonic SC-UX102E—who wins on clarity?
FX10/12 has better midrange detail thanks to a dedicated 25 mm dome tweeter; UX102E uses a single full-range driver, sounding boxy above 12 kHz [Philips Manual, 2017; Panasonic Service Sheet, 2017].
What power output do I really need for a 12 m² bedroom?
A pair of 20–30 W RMS speakers reaches 85–88 dB SPL, matching normal TV volume at 2 m. Anything larger mostly provides extra headroom, not volume [AudioEngineering, 2022; Elektroda, #16591814].
Are the side drivers on LG CM2760 active woofers or passive radiators?
They are active 130 mm woofers driven by the main amp; the lower front circle is only cosmetic [Elektroda, Jericho24, #18429285; LG Service Manual, 2017].
Why do store wattage labels look exaggerated?
Retail boxes cite PMPO or peak wattage—often 2-4× higher than RMS. RMS reflects continuous power and is the figure you should compare [FTC Rule, 2000].
Should I buy an all-in-one tower or separate amp with speakers?
Separates offer upgrade paths and truer specs but cost 30–70 % more for similar loudness. All-in-ones like CM2760 bundle BT, USB, radio and save space [Elektroda, #16591814; Crutchfield Guide, 2023].
How can I test a mini-system quickly in-store?
  1. Stream a familiar FLAC via Bluetooth.
  2. Switch EQ off; raise volume to 75 %.
  3. Walk to room corner; listen for rattles or bass drop. A five-minute check reveals enclosure buzz and harsh treble [RetailAudio, 2021].
What fails most often in budget towers?
Volume encoder wear tops the list: 1 in 6 LG and Panasonic towers reported erratic volume within three years [ConsumerReports, 2022]. Overheating amps rank second, usually after extended 90 %-volume use.
How do I pair a phone with the CM2760?
  1. Press FUNCTION until “BT” shows.
  2. Hold PAIRING for 2 s; display flashes.
  3. Select “LG CM2760” on the phone. Connection completes in ≈5 s; range is 10 m line-of-sight [LG Manual, 2017].
