Renault laguna II - einspritzung defect pops up after starting the turbine
gdwymx 12291 19
What can cause a Renault Laguna II 2.2 dCi to show an “einspritzung defect” message only when the turbo starts or the revs rise above 3000 rpm, and how should it be diagnosed?
Start with proper diagnostics in Clip and read the actual fault number and live parameters, not just delete errors [#16592842] [#16596064] Check injector correction values and how much boost the turbo makes, because those readings can point to the failing system [#16595008] Also inspect the vacuum system and the turbo control valve, since boost-related faults can come from incorrect vacuum or a sticking actuator [#16593358] The forum also suggested checking whether the EGR is blocked, but in this case disconnecting the EGR did not change the problem [#16592252] [#16592478] Replace the fuel filter as well, because it had not been changed and was suggested as part of the diagnosis [#16592813] [#16592842]
  • #1 16591532
    gdwymx
    Hello, I have a problem with the car, since the purchase I get the error '' einspritzung defect '', it pops up either in the morning or while the revs will jump above 3 thousand and the turbine will start. All the time I was extinguishing the car for a few seconds and after restarting the error disappeared, and during a quiet drive he does not pop out. What can this be a fault ? how to fix this malfunction?
    Moderated By T5:
    3.1.15. Do not ask immediately in the forum, if you have not checked anything yourself or attempted self-diagnosis. Remember that advice is given remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and brief description of the fault.
  • #2 16591889
    mcezar
    Rate: 19
    Are there also problems with a decrease in power?
  • #3 16591892
    genek1000
    Help: 289
    Rate: 1057
    First, diagnose what this error is.
  • #4 16592001
    gdwymx
    The drop in power is imperceptible, just starting to slightly kick in black
  • #5 16592252
    mcezar
    Rate: 19
    Check that your EGR is not blocked
  • #6 16592478
    gdwymx
    After disconnecting the EGR, unfortunately, it is the same, the error shows after turning on the turbine, and the turbine was replaced
  • #7 16592514
    sebap
    Help: 538
    Rate: 1082
    Is the flowmeter OK?
    Will you finally do any diagnostics? You haven't even written what engine it is.
  • #8 16592604
    mcezar
    Rate: 19
    Check the candles
    Moderated By CameR:
    Maybe you will develop the "candles" thread and explain why they can affect the described fault.
    How to check candles according to You ?
    Reg. 3.1.11. Do not send messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #9 16592618
    gdwymx
    I write specially here because maybe someone had a similar problem and say something :P
    the engine is 2.2 dci
    The flow meter is functional, the candles are the same
  • #10 16592813
    sebap
    Help: 538
    Rate: 1082
    Fuel filter when you replaced it?
  • #11 16592833
    gdwymx
    The fuel filter was not changed, the car just recently had a turbine installed, so only recently I drive it
  • #12 16592842
    sebap
    Help: 538
    Rate: 1082
    Then replace it and do diagnostics with Clip. Diagnostics, not reading errors.
  • #13 16593358
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    The vacuum must be correct in the system and the turbine control valve working properly.
  • #14 16594955
    gdwymx
    I will add that the car after lighting the error does not lose power, the car was connected to the computer errors have been deleted, but after traveling a dozen or so kilometers, the same thing still pops up
  • #15 16595008
    sebap
    Help: 538
    Rate: 1082
    What parameters were read? Injector correction? How much turbo blows?
  • #16 16595329
    Help: 1405
    Rate: 6430
    gdwymx wrote:
    the car was connected to the computer, errors were deleted
    So what are they now?
  • #17 16595365
    gdwymx
    the error is still the same
  • #18 16595673
    Help: 1405
    Rate: 6430
    But which. Give me the number and I'll tell you what doesn't work.
  • #19 16596022
    gdwymx
    The error still pops up the same``einspritzung defect '' what number?
  • #20 16596064
    sebap
    Help: 538
    Rate: 1082
    Error number from Clip or other diagnostic equipment.
The discussion revolves around a persistent "einspritzung defect" error in a Renault Laguna II, specifically occurring when the turbine engages or during high RPMs. The user reports that the error temporarily clears after restarting the vehicle but reappears after a short drive. Various troubleshooting suggestions are provided, including checking the EGR valve, flow meter, fuel filter, and ensuring proper vacuum in the system. The user confirms that the EGR was disconnected and the turbine replaced, but the issue persists. Diagnostic checks are recommended, emphasizing the need for detailed error codes from diagnostic equipment to identify the root cause of the problem.
