Renault Megan II 1.6 + Lpg - ESP / ASR error DEFECT and Coil Loss
acapulko 19530 14
Why does my Renault Megane II 1.6 LPG show ESP/ASR defect and service lights together with a cylinder misfire fault?
The ESP/ASR and service lights were caused by a broken ABS sensor wire, not by the ignition coils or LPG system. Because ESP/ASR depends on ABS communication with the engine, an ABS fault can light the service warning and disable ABS/ASR [#16197442][#16197520] The suggested checks were to read ABS faults with a tester and measure the wheel sensor resistance at the plug; the four sensors should be similar, with a good one around 1.1–1.4 kΩ [#16197442] In this case, the actual defect was found at the rocker, where the ABS sensor wire had detached and then broken when turning [#16198756][#16202926]
  • #1 16169528
    acapulko
    Rate: 8
    Hello. I have a problem namely ESP / ASR DEFEKT is displayed. Megan II 1.6 + LPG I would like to add that I have the easiest OBD computer for diagnostics. Once I had this way and it turned out that the coil was on the first cylinder (the one on the side of the clutch / box) and the car jerked and it was impossible to drive normally. After the exchange, the message disappeared and everything returned to normal. After one week, the message returned and shows the ignition failure on the 4th cylinder. After changing to another without change. I checked on 2 side and all the time the loss 4 shows. The car rides, accelerates and enters the turnover just as you need only the esp / asp and servis control. The only difference is that the gas has a slightly lower speed and does not work as smoothly as on petrol at idle. I do not know whether it is the fault of coils, wires or maybe the driver because I read that too. Any ideas, tips? greetings
  • #2 16169535
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    Ride on gasoline longer and do not turn on the gas at all.
  • #3 16170543
    Bunny82
    Help: 15
    Rate: 242
    And two are replace the candles for lpg because the used candles and gas-drifting coils are falling. Check before the candles are installed, the break can not be more than 0.8
  • #4 16170799
    acapulko
    Rate: 8
    The candles are new, replaced for the first time but for the usual catalog ngk.
  • #5 16170873
    zfv
    Check the coil 4 wires to the ECU.
  • #6 16171061
    Ireneo
    Help: 746
    Rate: 2461
    Check also the compression.
  • #7 16186722
    acapulko
    Rate: 8
    Hello, I have done a pressure measurement and there are more than 12 on each one. Tomorrow, I have to drive to the gasifier or it is not a gas fault.
  • #8 16194252
    acapulko
    Rate: 8
    Hello I put in a new injection molding and the new mapping engine goes beautifully on the gas but the error still shines.
  • #9 16194481
    citromaniak
    Help: 53
    Rate: 389
    And the abs works well? Maybe there is a problem with the sensors?
  • #10 16197144
    acapulko
    Rate: 8
    Hello. I checked abs today and the car brakes as if he did not have it. The wheels are skidding. Does anyone know if you can check the abs scales?
  • #11 16197442
    drdrug
    Help: 25
    Rate: 178
    The abs / asr system is shining on the board, the abs system does not work. Unfortunately, just as stupid as in the citroen c5, the abs / asr control lights up the service. To be sure, connect the tester and go to Abs, see if there are any errors. The sensors can be checked with the meter by measuring the resistance on the plug from the sensor, all 4 abs sensors need to be close to each other, the good sensor is about 1.1-1.4 kOma
  • #12 16197520
    Help: 1404
    Rate: 6402
    This is normal and how do you imagine the torque control at ESP without communication with the engine?
  • #13 16198756
    acapulko
    Rate: 8
    Hello. Problem solved. the reason was the abs sensor wire cut. Best regards and thank you for your help
  • #14 16199157
    Ireneo
    Help: 746
    Rate: 2461
    Where was he cut?
  • #15 16202926
    acapulko
    Rate: 8
    at the rocker he detached himself from one place and had to cut through the turn
✨ The discussion revolves around a Renault Megane II 1.6 LPG experiencing an ESP/ASR defect and ignition failure on the fourth cylinder. The user initially resolved a similar issue by replacing a faulty coil but encountered a recurrence of the error after a week. Suggestions from other users included checking the spark plugs, coil wiring to the ECU, and compression levels. The user confirmed that the spark plugs were new and later replaced the injection molding, which improved engine performance on gas but did not eliminate the error. Further investigation revealed that the ABS system was malfunctioning, leading to the ESP/ASR error. Ultimately, the problem was traced to a cut wire in the ABS sensor, which was repaired, resolving the issue.
