Identifying Diagnostic Connector Type in 2002 Peugeot Partner 2.0 HDI for ELM327 Use
pablo95 9486 4
  • #1 16591760
    pablo95
    Rate: 9
    Hello. What Type of diagnostic connector is in my peugeot partner? I do not know this and I would like to buy an ELM327 diagnostic cable, but I do not know if it is an OBD or OBD2 / EOBD connector.
    My car is Peugeot Partner 2.0 HDI (90HP), 2002 5drzwi
    Attached photos of the connectors on my vehicle
    Thank you for your answer
    Ps please don't write yearbooks from which OBDII / EOBD system was installed in cars because I know that there is a possibility that the vehicle has a newer diagnostic system because it was produced during the transition period.
    • Identifying Diagnostic Connector Type in 2002 Peugeot Partner 2.0 HDI for ELM327 Use 20170715_140630.jpg (962.88 KB) You must be logged in to download this attachment.
  • OBD-II standard uses the 16-pin EOBD connector
    #2 16591783
  • #3 16591807
    pablo95
    Rate: 9
    Thank you for the explanation but this is not exactly the answer to my question. I meant to determine if the socket presented in the attached picture is an EOBD / OBDII socket
  • #4 16591818
  • #5 16591829
    pablo95
    Rate: 9
    Dude, I know EOBD and OBDII are the same. Only EOBD is the European version of the OBDII system. But never mind. I found the answer after a few hours of searching.
    Peugeot Partner 2.0 HDI 2002 (90HP) 5 doors has an EOBD / OBDII socket and communicates with the diagnostic interface in the KWP2000 protocol (ISO 14230) And I know that the ELM327 cable will fit my car
