[Solved] Peugeot diagnostics - PP2000 interface type B + DiagBox 7.02 -> reads VIN, an
OPservator 21243 4
  • #1 17229453
    OPservator
    Help: 555
    Rate: 1231
    Hello!
    Since yesterday I was tired of installing DiagBox.
    PP-2000 cable type B on Lexia 3 through DiagBox 7.02.
    My problem is - the interface works 100%, during the "tick" diagnosis, which means it sends a signal to the on-board computer.
    However, it then returns the value "no dialogue" with each separate calculator.
    System: Win 10 64-bit
    I would like to add that the cable was tested on two Peugeots - 308SW (2008) and 207 (2006) - in both cases the result is identical.
    Piasek80
    Help: 129
    Rate: 666
    Planet and Lexia are terrible diagnostic dummies. They work properly only on completely clean XP.
    W \ w do not work in a 64bit environment.
    99% of problems related to them result from the operating system on which the combinations of partitions, some virtual drives, etc. have been set.
    Only a clean system partition with XP, necessarily a 32-bit environment and will work properly.
  • #3 17230409
    sly_1978
    Help: 34
    Rate: 284
    OPservator wrote:
    Hello!
    On Win7 32bit DB 7.52 I only work until 2005. I have XP on my second boot and it works on every year.
  • #4 17273757
    OPservator
    Help: 555
    Rate: 1231
    Okay, there was something busted in the previous interface, the seller exchanged for a new one.
    @ sly_1978 in my case the situation is quite the opposite - on laptop win7 32-bit and win10 64-bit (where win10 has a virtualbox with winxp 32-bit) cars operate from 2006 up (this new calculator).
    I went to see my sister for a visit (206 from 2004), he read the VIN immediately. Then a selection menu appeared - Diagtool (not diagbox ...) or PP2000.
    After choosing whatever option he redirected to PP2000 anyway - in effect he said something, that the interface is used by another program or something.
    I tried to do as a cable vendor wrote - unplug USB, click OK to go back to the selection menu, connect and re-enable PP2000 to the effect.
    After X attempts, he throws me some error with WinCAD.
  • #5 17309462
    OPservator
    Help: 555
    Rate: 1231
    replacement of a faulty interface
