Air conditioning Toyota Corolla - Toyota Corolla E12 air conditioning
Damianv6150 7824 3
  • #1 16592103
    Damianv6150
    Hello, I have a problem with the air conditioning toyota corolla e12 2.0 diesel, 2003, europe version
    the compressor starts briefly, the relay is complete, the fuse is also, the voltage reaches the relay and the pressure sensor, the sensor is new
    the air conditioning button is lit when it is turned on, but the air conditioning does not start
    Does anyone know where to look for the cause next?
  • #2 16592141
    jaszczur1111
    Help: 173
    Rate: 494
    Either too little gas or a clogged system on the high pressure side (filter, expansion valve). Another question is, does it start once and does it try no more or does it turn on periodically for a while?
  • Suspected controller or wiring fault preventing compressor relay signal
    #3 16592165
    Damianv6150
    The gas is full, it does not move at all, it starts only when I make a short circuit in the relay socket from the compressor, then the compressor starts and the air conditioning cools, the fans start and everything works fine, but nothing goes without a short circuit
    is it possible that the air conditioning controller has fallen or there is a break in the system and the controller does not give a signal to the compressor relay?
  • #4 16592172
    jaszczur1111
    Help: 173
    Rate: 494
    Unfortunately yes. In my Ford Mondeo, I made a bypass. Then you have to consciously use the air conditioning. If the refrigerant escapes, the compressor will be damaged, so if it is not cooling, but it should be turned off. For now, the second year of operation without problems. Such things are at your own risk.
