[Solved] Corolla E12 2002 - The right dipped bulb is barely lit, the long bulb also turns
Tremolo 8022 5
  • #1 17039196
    Tremolo
    Help: 1016
    Rate: 497
    According to the information from elektroda.pl, control is done by entering the weight. Now there is 4V on the bulb. (In relation to the weight on the booth, it is 0.5V and 4V (and at the same time with poor lighting, long light also breaks through (comparable brightness). I suspect the voltage range is the same? Does anyone have a schematic of this installation? normal W5W positional work well on both sides Road and low beam left OK Bulbs H7
    andrzej20001
    Help: 1578
    Rate: 6669
    The HR Head light fuse under the hood fell off.
    andrzej20001
    Help: 1578
    Rate: 6669
    Not parasitically from a working lamp
  • #5 17040259
    Tremolo
    Help: 1016
    Rate: 497
    Thank you, it was that simple. When I moved the fuse, they returned to normal operation. I pulled it out and found it burnt. Replaced it and it works fine. I listened to a mechanic with burnt masses, with 24V bulbs connected.
  • #6 17040263
    Tremolo
    Help: 1016
    Rate: 497
    Added after 49 [seconds]:
    Fuse replacement
