Toyota Corolla e11 1998 1.3 4E - ABS not working (no ignition test)
Game Master 13158 16
How can I diagnose an ABS system in a 1998 Toyota Corolla E11 when the ABS warning light does not come on with ignition?
Check the ABS warning bulb first, because if the ABS does not work and the lamp stays off, the bulb may be burned out or disconnected [#16980152][#17728853] To test it, remove the instrument cluster, take out the bulb, and check it with a meter or by applying 12 V [#16980152] If the bulb is OK, read the ABS controller faults with a diagnostic interface; at home there is no practical way to do this without such equipment, so a workshop or someone with the interface is needed [#16980150][#16980198] After that, if nothing obvious turns up, inspect all fuses thoroughly and check the ABS toothed rings on the wheel hubs and the ABS sensors, preferably from a pit or lift, because cracked or dirty rings and damaged sensors are common on older cars [#16980209][#17728853] Replacing only the bulb or the ABS module without diagnosis will not repair the ABS [#16980152][#16980214]
  • ABS warning lamp may be burned out or disabled
    #1 16980052
    Game Master
    I warmly welcome.
    I am the happy owner of a Toyota Corolli e11 from 1998. 1.3 4E-FE petrol engine, liftback body type :)
    Everything works fine except for one drawback that bothers me.
    ABS is not working, this is not signaled! ; /
    I checked all fuses responsible for ABS operation. I tried to detach them, causing a break in the circuit, but after turning to ignition, nothing else on the board.
    What do you advise
    I enclose photos of fuse boxes and a diagram which I suggested.
    • Toyota Corolla e11 1998 1.3 4E - ABS not working (no ignition test) bezpieczniki pod kierownicą.jpg (2.69 MB) You must be logged in to download this attachment.
    • Toyota Corolla e11 1998 1.3 4E - ABS not working (no ignition test) bezpieczniki pod maską.jpg (2.36 MB) You must be logged in to download this attachment.
    • Toyota Corolla e11 1998 1.3 4E - ABS not working (no ignition test) schemat.jpg (225.56 KB) You must be logged in to download this attachment.
  • #2 16980116
    lukasrsv
    Help: 41
    Rate: 165
    And the bulb from the ABS indicator is sometimes not damaged?
  • #3 16980142
    Game Master
    Thank you for your answer. How to check this bulb? Need to spin the clocks?
    PS. turns on after turning the ignition key
    - orange ENGINE
    - in red OIL, HANDBRAKE, BATTERY AND AIRBAG (goes out after a few seconds)
    rafcio_21
    Help: 137
    Rate: 295
    Check the bulb circuit as a colleague above suggests and whether you can read the errors from the ABS controller. ?
    lukasrsv
    Help: 41
    Rate: 165
    Unfortunately, you need to remove the clocks. Then you take out the bulb and you can check it with a meter or connecting it to 12 V.
  • #6 16980182
    Game Master
    Wow, what does it mean to be able to read errors from an ABS driver? :) Only professional connection to a computer comes into play or something like that can be read at home?
  • #7 16980194
    rafcio_21
    Help: 137
    Rate: 295
    I mean, do you have a friend (familiar workshop) who could read your mistakes?
    lukasrsv
    Help: 41
    Rate: 165
    For this you need a diagnostic interface and without it at home, nothing will come of it.
  • #9 16980199
    Game Master
    Unfortunately not
    rafcio_21
    Help: 137
    Rate: 295
    It is at home that you can get to the meter and check the light bulb, and if it turns out that it works, it remains to check all the fuses thoroughly and then, as you will find nothing, there is a workshop and connection to the controller.
  • #11 16980212
    Game Master
    I'm afraid that the previous owner was offended by this control and did something with it. Although, sometimes I really press the brake pedal hard and intensely, I have the impression that something in the chassis is shooting, but the brake pedal does not feel bouncing. With a slight inhibition of this symptom I did not notice :) In both cases, in my opinion, the car slides onto the lock :D
  • #12 16980214
    lukasrsv
    Help: 41
    Rate: 165
    I suggest looking for a diagnostician with such an interface because replacing a burnt out bulb alone will not repair ABS.
  • #13 16980220
    Game Master
    I will agree with that :)
    Okay, thank you for now. I will try to comprehend it :)
  • #14 16980229
    rafcio_21
    Help: 137
    Rate: 295
    Write what came out of the diagnosis in the workshop. best regards
  • #15 17728757
    BartekKRK-BDG
    I'm reactivating a thread. I have the same problem. I wanted to try to replace the ABS module blind ... I just don't know where it is :P Can you tell me more or less where this module is located?
    Best regards!
  • #16 17728853
    gimak
    Help: 614
    Rate: 1678
    If the ABS does not work and the indicator light is off, it is either burned or, as someone wrote above, the bulb is disconnected. Replacing the bulb or connecting the lamp alone will not fix the ABS. At this age of the car, you should take into account damaged (contaminated or cracked) ABS toothed rings on the wheel hubs or even damaged ABS sensors. The condition of the rings can be checked from the channel or on the lift - I would start with that.
  • #17 17728887
    BartekKRK-BDG
    Only I don't want to change the light bulb :-) I want to replace the ABS control module. Mechanics checked the pump and after connecting 'briefly' (from what they said) it worked. That is why I am thinking about replacing the ABS module :-) I just don't know where he is.
The discussion revolves around a 1998 Toyota Corolla E11 with a 1.3 4E-FE petrol engine, where the owner reports that the ABS system is not functioning, and there is no warning light indicating a fault. The owner has checked all relevant fuses without success. Responses suggest checking the ABS indicator bulb, which may be burnt out or disconnected, and recommend using a multimeter to test it. Additionally, it is advised to read error codes from the ABS controller, which requires a diagnostic interface. Other potential issues include damaged ABS toothed rings or sensors. One participant inquires about the location of the ABS control module, indicating a desire to replace it. The consensus is that simply replacing the bulb will not resolve the ABS issue, and professional diagnostics may be necessary.
TL;DR: For a 1998 Corolla E11 1.3L (4E‑FE), an ABS light that never illuminates at key‑on often means the bulb/circuit was disabled—"ABS is not working, this is not signaled!" [Elektroda, Game Master, post #16980052]
Why it matters: This FAQ helps E11 owners troubleshoot a no‑ABS‑light issue and decide what to check at home vs. in a workshop.
Should the ABS light come on when I turn the key?
Yes. If it never lights at key‑on, suspect a failed or disconnected bulb or its circuit. Check the cluster first. [Elektroda, lukasrsv, post #16980116]
How do I check the ABS bulb on a Corolla E11 at home?
How‑To: 1. Remove the instrument cluster. 2. Take out the ABS bulb and test it with a multimeter or 12 V. 3. Refit and retest the key‑on lamp check. “Then you take out the bulb and … check it with a meter or 12 V.” [Elektroda, lukasrsv, post #16980152]
Can I read ABS faults at home without special tools?
No. You need a diagnostic interface to read ABS controller faults; without it, home diagnosis is limited. [Elektroda, lukasrsv, post #16980198]
What should I check before visiting a workshop?
Verify the ABS lamp bulb and circuit, then recheck all ABS fuses. If those pass, proceed to professional diagnostics. [Elektroda, rafcio_21, post #16980209]
Will replacing the ABS bulb fix my ABS?
No. The lamp only reports status. “Replacing the bulb or connecting the lamp alone will not fix the ABS.” [Elektroda, gimak, post #17728853]
What common faults disable ABS on an older Corolla E11?
Typical causes include cracked or contaminated toothed rings on hubs and failed wheel speed sensors. Inspect rings on a lift. [Elektroda, gimak, post #17728853]
Where is the ABS control module/pump located on the E11?
This thread doesn’t state an exact location; a mechanic jumped the pump directly. Trace from the master cylinder to the hydraulic unit. [Elektroda, BartekKRK-BDG, post #17728887]
Why is my ABS inactive but the ABS light never comes on?
The previous owner may have disconnected the lamp or the bulb is burned out, hiding ABS faults. [Elektroda, gimak, post #17728853]
What if I don’t have a scan tool—what’s the best next step?
Find a diagnostician with the proper ABS interface; lamp or bulb replacement won’t restore ABS function. [Elektroda, lukasrsv, post #16980214]
I pulled ABS fuses but the dash still showed nothing—is that normal?
If pulling ABS fuses changes nothing on the dash, the ABS lamp circuit may already be disabled. [Elektroda, Game Master, post #16980052]
How does the car brake when ABS is offline?
Conventional braking remains. Expect wheel lock and no pedal pulsation under hard stops, as described by the owner. [Elektroda, Game Master, post #16980212]
