Chinese DIY Tube Amplifier Kit from AliExpress: Per6J1 Valve Pre-Amp, 6J1, 12V Power Supply
uraharu 4527 6
  • Questioning sound quality of transformerless 12 V tube preamp
    #1 16592636
    uraharu
    Rate: 26
    could anyone tell me something about this type of construction?
    https://www.aliexpress.com/item/Per6J1-Valve-...J1-on-Musical-Fidelity-X10-D/32666559198.html
    there is not much information in the description, but browsing the diagrams of simple tube amplifiers there is always a mains transformer and 2 (for stereo) speaker transformers.
    These elements are not here, it works based on a simple 12v power supply
    Can a decent sound quality be obtained through such a simple amplifier?
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    Buddy is a preamplifier, therefore, it doesn't require output current and the tubes used can work at low voltages. Similar constructions have been described by EdW.
    edberg
    Level 30  
    Help: 133
    Rate: 117
    This is a preamplifier, not a power amplifier, so you don't have transformers on the output. The output of this kit is connected to a power amplifier.
  • Speaker output should come from the TDA2030A amplifier
    #4 16592664
    uraharu
    Rate: 26
    Thanks for the clarification :)
    that is, how I would route the audio output from this tube preamplifier to such an amplifier
    https://www.aliexpress.com/item/New-Electric-...A2030A-hifi-stereo-amplifier/32630906654.html
    could I connect the speakers at the output of this amplifier?
    after all, even this amplifier doesn't have speaker transformers
    forgive my questions, I want to start my adventure with electronics, but I can't understand how they got rid of such an element
    I would like to create a small amplifier (some kind of hybrid or a clean tube) for "fun" up to 1-2 W on the audio output
    and I am thinking about this type of ready that would help me understand the principle of operation
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    Semiconductor amplifiers (as in the last link) do not require speaker transformers. You can connect speakers directly. The speaker transformer matches the speaker impedance (low) to the output impedance of the tube amplifier (high).
  • #6 16592722
    uraharu
    Rate: 26
    in this case, does the sound transformer lose sound quality?
    Is such a structure i.e.
    the lamp preamplifier outputs a signal to the solid state amplifier and then to the speakers makes sense? Will it work if I combine these 2 elements in such a way?
    Transformer coloration defines tube amplifier sound
    #7 16592805
    viayner
    Help: 1563
    Rate: 2052
    the introduction of a transformer into the system causes "changes" in the sound and whether they are positive or negative changes (distortions) depends on the refinement of the system. Due to their construction, audio type transformers do not carry very high frequencies of 100kHz and whether there is a need to carry them is another matter. On the other hand, for transformers to carry the lowest sounds they must have high inductance = very large dimensions.
    The sought after sound of the tube amplifier is caused in the vast majority by the presence of a transformer.
    If you are looking for a tube sound then adding a tube preamplifier to a power semiconductor amplifier will not change much, in this respect it is better to do the opposite. Examples are OTL systems or other transformerless tube systems that do not sound so tube-like.
    Regards
The discussion revolves around a Chinese DIY tube amplifier kit, specifically the Per6J1 Valve Pre-Amp, which operates on a 12V power supply. Participants clarify that this kit is a preamplifier, not a power amplifier, and thus does not require output transformers. The output from the tube preamplifier can be connected directly to a solid-state power amplifier, such as the TDA2030A, allowing for speaker connection without transformers. Concerns about sound quality and the role of transformers in audio systems are addressed, noting that while transformers can introduce distortions, they are essential for achieving the characteristic tube sound. The conversation emphasizes the compatibility of combining tube preamplifiers with solid-state amplifiers for a hybrid audio setup.
