Converting Telescopic VHF Antenna to UHF for DVB-T MUX 8 Reception: Step-by-Step Guide
3798 8
  • #1 16594909
  • #2 16594954
    gumisie
    Help: 1667
    Rate: 2482
    Ksawery Filipiak wrote:
    I was able to receive all dvb-t MUX 1,2,3 channels on it. I would like to convert it into MUX 8
    Hello. You have confused the concepts of what you want to do in the topic title: "VHF to UHF." It is enough to extend this telescopic antenna to the appropriate frequency of MUX8 and set the appropriate polarization for this MUX8.
  • #3 16594970
  • #4 16594982
    gumisie
    Help: 1667
    Rate: 2482
    Yes, sorry, the MUX8 typo was corrected in the post, but the solution remains the same.
    Greetings.
  • #5 16594992
  • #6 16595002
    gumisie
    Help: 1667
    Rate: 2482
    Meaning to unfold to the right size?
    You wrote that it is a telescopic antenna. Pull it to the max, measure the length of the radiators and post it here on the forum and we'll see if it makes any sense to do something with this antenna.
  • #7 16595027
  • #8 16595040
    gumisie
    Help: 1667
    Rate: 2482
    It may be too short, check the frequency at which the MUX8 is transmitting the one you intend to receive and use the simplified formula for the length of the radiator.
    300: frequency in MHz: 2 = length.
    Greetings.
  • #9 16595056
✨ The discussion revolves around converting a telescopic VHF antenna to receive DVB-T MUX 8 channels. The initial query seeks guidance on whether this conversion is feasible. Responses clarify that extending the antenna to the appropriate length for MUX 8 and adjusting its polarization is sufficient. Users suggest measuring the length of the radiators, which are noted to be 69 cm each, and applying a formula (300: frequency in MHz: 2 = length) to determine if the antenna is suitable for MUX 8 reception. The conversation concludes with the author expressing gratitude for the assistance provided.
