Understanding the Indicator Display on OPEL CORSA C 2004 1.4 - Image Included
mariomario 42972 14
What does the warning light on an Opel Corsa C 1.4 (2004) mean?
The icon is the Opel “key” warning and it points to an electronic fault in the drive-train/engine management system, not the usual check-engine light. It can relate to engine electronics, the immobilizer/electronic starting block, or the automatic/Easytronic transmission [#16597128][#16596695] A generic scanner may miss the fault, so the recommended next step is to read the errors with a dedicated Opel diagnostic tool at a workshop [#16596808][#16596695]
  • #1 16596676
    mariomario
    Help: 17
    Rate: 140
    Hello, I have a question about what the indicator on the OPEL CORSA C 1.4 2004 is showing below. ?
  • #2 16596688
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    A very poor photo.
    From what I see is check.
    This indicates a problem with the engine control.
  • #3 16596695
    Wojtek 2007
    The indicator is responsible for the engine electronics, the electronic starting block, the automatic transmission, the Easytronic transmission
    What exactly happens to you will show a computer. Go somewhere to the workshop where they will follow it and read the mistakes
  • #4 16596808
    ociz
    Help: 1379
    Rate: 3486
    The same as "helikopterek", or "check engine", except that not every universal tester will read all the errors that can cause this indicator to light up. It's best to use a dedicated Opel.
  • #5 16596818
    mariomario
    Help: 17
    Rate: 140
    "check engine" is definitely not - I attach a full photo
    check engine is "floor above"
    Generally, I would just like to know what this icon means. Because the car drives normally and only this indicator when driving lights up.
  • #7 16596896
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 744
    Google is not working? And no, it works !!!
    http://dixi-car.pl/kontrolka.htm Only the key in the level.
    http://forum.opel24.com/topic/8432-swiecaca-kontrolka-zoltego-samochodu-z-kluczem/
    And what else do you need? Ensure that you can still go on this way?
    A runner to the workshop, and the closest one (of course, he knows what and how).
  • #8 16596897
    enhanced
    Help: 963
    Rate: 883
    This lamp can come on in two situations: either the oil life has run out (time for a periodic inspection of the car) or there has been a failure. You can try to go, preferably straight to the site.
  • #9 16596902
    maurycy123
    Help: 226
    Rate: 744
    Kurtka na wacia wrote:
    The floor above is rather a steering wheel control.
    Probably not. This is the "Cheack Engine" control. You do not know, do not write stupid.
  • #10 16596945
    arturdip
    Help: 170
    Rate: 324
    The car signals over the course of the car (review)
  • #12 16597128
    milejow
    Help: 1563
    Rate: 5149
    enhanced wrote:
    This lamp can come on in two situations: either the oil life has run out (it is time for a periodic inspection of the car),
    Do not repeat nonsense.
    The key control is an electronic fault of the drive train control system.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #13 16597240
    mariomario
    Help: 17
    Rate: 140
    So look for causes in the candles / engine control module / engine sensors / fuel filters / oil filters? Where else ?
    PS. The car walks normally, has power, the engine does not kick, it walks steadily and stably, nothing abnormal happens
  • #14 16597284
    maurycy123
    Help: 226
    Rate: 744
    It is better to look for a problem with a person with appropriate competences. You can replace the "half" of the car yourself and you will continue to write here that you have problems.
    Until it happens and then you'll cry.
  • #15 16597290
    ociz
    Help: 1379
    Rate: 3486
    Topic exhausted. I close.
The discussion revolves around the indicator display on the OPEL CORSA C 1.4 from 2004, specifically addressing a warning light that the user is unsure about. Responses indicate that the light may signify an engine control issue or a need for a periodic inspection. Several users recommend using a dedicated Opel diagnostic tool to read error codes, as generic testers may not capture all potential issues. The conversation highlights the importance of consulting a qualified technician for accurate diagnosis and resolution, especially since the vehicle appears to be functioning normally despite the warning light.
