Deciphering Error Codes 000000C00F & 0000008003 on Opel Zafira B 2008 1.9.9cdti Display
bogumil67 8940 8
  • #1 16184426
    bogumil67
    Hello gentlemen ... I search all over the net and I can't find what the code means. 000000C00F on the menu display. In the photo it looks like this ... How to read what was wrong with him? ... I know that this is a remembered code that automatically clears, but without a reason he did not remember it. Frequently, the code 0000008003 also appears. Please help
    Deciphering Error Codes 000000C00F & 0000008003 on Opel Zafira B 2008 1.9.9cdti DisplayWP_2017010... Kopia.jpg (201.24 kB)You must be logged in to download this attachment.
  • #2 16193485
    szczupx
    Level 19  
    Help: 29
    Rate: 94
    Read the error through the normal interface, this way you will not get what and how.
  • #3 16193574
    bogumil67
    Just yesterday they are zero. I connected op-com and showed no error anywhere
  • #4 16301537
    bogumil67
    Hello again and again the numbers appeared 0000008003 ... did anyone kuma what is this ???? no errors on op-com
  • #5 16304946
    pako150
    Help: 18
    Rate: 174
    No errors in the entire vehicle?
  • #6 16305474
    bogumil67
    There are no errors whatsoever ... I found out that this STORE with four zeros, these are error codes stored, which actually resets after some time. And those zeros after (00008003) damn knows what it means and what it is used for.
  • #7 16307071
    pako150
    Help: 18
    Rate: 174
    And did you diagnose when the error occurred?
  • #8 16307242
    hobbista
    Help: 108
    Rate: 173
    bogumil67 wrote:
    I learned that it is STORE with four zeros, these are error codes memorized
    Error codes or warnings? There is no info on this topic. You read it in so-called testmode function. Any errors, if you want to read from the engine driver yourself, you can fumble (the way you will find on the net) I think you are looking for sensation, let go, sleep peacefully.
  • #9 16307987
    bogumil67
    yes and there is nothing
    Added after 14 [minutes]:
    What warnings are they for? This is the last item in the BID display in testmode. STORE I know that this is an error stored in the memory that occurred before, after some time it resets (I tested it when I disconnected the air flow meter) I just do not know what the numbers mean STORE these zeros ... , I do not know why
The discussion revolves around the error codes 000000C00F and 0000008003 appearing on the display of an Opel Zafira B 2008 1.9 CDTI. Users are trying to decipher these codes, noting that they are stored codes that clear automatically over time. Despite using the OP-COM diagnostic tool, no specific errors are found in the vehicle. Participants suggest that the codes may indicate stored errors from previous issues, but their exact meanings remain unclear. The conversation highlights the need for further investigation into the context of these codes and their implications for vehicle diagnostics.
