Midland M-Mini CB Radio: Tuning & Communication Issues on Germany's 28th Channel
Agdamski 6519 12
How do I configure a Midland M-Mini CB radio so I can talk to other users on channel 28 in Germany?
Set the radio’s sensitivity and noise reduction (squelch) correctly; after changing sensitivity to 0.6 and noise reduction to 18, the radio started working and calls could be made and answered [#16598013][#16600927] It’s also worth checking whether the radio is set for the correct channel spacing (“zeros” or “fives”) and mode, since Germany was noted as using FM and the “fives” setup [#16597455][#16597768] If two identical radios can only talk to each other, they are likely both misadjusted rather than tuned to local conditions [#16597993]
  • #1 16597092
    Agdamski
    I have a problem with "tuning" the radio.
    In Germany on 28th channel I can't communicate with anyone. I will add that my friend has the same radio and we can talk to each other.
    The description that was included in the set gives nothing.
    There is only basic information and a description of the buttons and icons on the display.
    Someone something?
    kokapetyl
    Help: 1787
    Rate: 2104
    Agdamski wrote:
    In Germany, on channel 28, I can't communicate with anyone
    How does it look (connectivity) on other channels?
    How can you be sure that other users in your area are using this channel?
  • #3 16597371
    Agdamski
    In PL we fly to 19, abroad 28.
    It worked like that on an old radio.
    In addition, a colleague once called someone, someone answered, which colleague did not hear, and I did, for a while we did not hear anything, but after setting everything the same, it is ok.
    Ie. we can talk, but only us.
    I will add that we have identical radios.
    c2h5oh
    Moderator
    Help: 502
    Rate: 753
    Is the radio working in "zeros" or "fives"?
  • #5 16597690
    Agdamski
    I don't know how to check it, but it is set to the frequency in Poland - as written in the manual.
    It had to be good because I heard the guy he was sending a friend to.
    yes2mike
    Help: 258
    Rate: 322
    DE is talking in "Fridays" and FM as well as far as my memory is correct.
  • #7 16597796
    Agdamski
    I will agree with you here. But...
    In Poland we go to 19 AM, crossing the borders we drive in to 28 AM, which is only the channel.
    In addition, setting the first time wbilam settings for PL. And here nothing changes whether I'm in PL or in DE. Only channel
    From 19 to 28.
    yes2mike
    Help: 258
    Rate: 322
    Let a friend ask how others have radios set up, because if you get along with each other and you also have antennas between you, the radios are obviously misaligned. There is no other option.
  • Sensitivity and noise settings restored communication
    #9 16598013
    Agdamski
    I think to call the store where I bought the radio, they have a service there and the best man who deals with it, explain to me step by step what, where and how to change / set. Yes "in a pathological way"
    Unless I hit a Tir along the way.
    Thanks anyway.
    Added after 8 [hours] 57 [minutes]:
    The topic can be closed.
    I got an answer on the website.
    I have to set the sensitivity and noise regulation. He even gave similar values at which it should work well. The only problem is that I'm now in De and these settings will not be as accurate as in Pl.
    After a quick reboot on the new settings it somehow works, you can now call someone and get an answer.
    Thank you all for the answers and advice.
  • #10 16599611
    yes2mike
    Help: 258
    Rate: 322
    So what have you changed? Did you turn the knob and it works?
  • #11 16600927
    Agdamski
    On this radio, the only knob is the volume knob. The rest are buttons on the pear - top / bottom.
    I changed the sensitivity to 0.6
    And noise reduction at 18
    Now works ?
    This is how it looks. Midland M-Mini CB Radio: Tuning & Communication Issues on Germany's 28th Channel1500660359...861823.jpg (1.16 MB)You must be logged in to download this attachment.
  • #12 16600990
    yes2mike
    Help: 258
    Rate: 322
    And in this way you also helped others, because sooner or later someone will be looking for a solution to an identical problem ?
  • #13 16601490
    Agdamski
    That's what this is about ?
The discussion revolves around tuning issues with the Midland M-Mini CB Radio on Germany's 28th channel. The user reports being unable to communicate with others on this channel, despite successfully communicating with a friend who has the same radio. Various responses suggest checking connectivity on other channels, ensuring proper frequency settings, and adjusting sensitivity and noise reduction settings. The user ultimately resolves the issue by setting sensitivity to 0.6 and noise reduction to 18, allowing for successful communication. The conversation highlights the importance of proper radio configuration and local channel usage.
