Best CB Radio Base Station Setups: ALAN 28 AM/FM, CTE 5/8 Wave Antenna (27MHz, 6.0m) for 20km Range
kubuswujo 12903 10
How can I build a CB base station that will be clearly heard at least 20 km away?
Use a 5/8λ base antenna on the highest practical mast; on CB, the antenna and its alignment matter more than the radio itself, and 20 km is realistic only with a good installation and favorable propagation [#17381252][#17381119] ALAN 28 is an old AM/FM set; the thread suggests it will work, but it is not especially valuable and newer radios may be a better buy [#17381252][#17381134] If you want a more modern option, consider an SSB-capable radio such as the Anytone AT-6666 or CRT 9900, or an ALAN 555 if you can find one in good condition [#17381252][#17374134] Several replies also warn that CB activity is low, so it is worth checking local traffic before spending much money [#17381134]
  • Need antenna and radio recommendations for 20 km CB range
    #1 17374078
    kubuswujo
    Rate: 71
    Hello!
    I would like to assemble some CB base kit
    The range in which I would like to be clearly heard is at least 20 kilometers.
    The antenna is installed in a village under the boat, about 5 km from the A1 and S8 motorways.
    What do you recommend? I was thinking about
    CB radio ALAN 28 AM / FM
    The base CTE antenna 5/8 wave with at 27MHz length 6.0 m
    but I'm not sure it's a good set
    Cuba
    Pedros050
    Help: 2471
    Rate: 3930
    Hello. I had Alan 555, if you had the opportunity to buy one, it is perfect.
  • #3 17381119
    Vic384
    Level 19  
    Help: 14
    Rate: 39
    Hi
    During my infatuation with CB, I had Grant as my base and Midland towel in my car. The base antenna is 7/8 per 4m mast on the roof of the building. In the car there was an interchangeable magnet rod with a 80 cm rod and a Boston 1800. The range with the magnet rod was about 25 km, with Boston there was no problem with Rzeszow - Sandomierz, i.e. about 70 km. In my opinion, the antenna is the most important in the base station, because radios have practically very similar parameters. It is very important to align the antennas.
  • #4 17381134
    SP5IT
    Help: 1300
    Rate: 1709
    The CB band is dead. Not much is going on at primary 40, even the carters switched to Janosik so as not to listen to the bluffings at 19.
    Apart from small groups of oldtimers, nothing happens.
    Outside of the CB band, there are still groups saluting their bases, but also not crazy.
    Fire up Kuba on what you wrote and see for yourself what and how. In case of what, you will not suffer a huge financial loss.
    Don't get messed up when you buy this 28, it's not worth more than $ 200 in perfect condition and with a box.
    M.
  • #5 17381252
    Jap
    Help: 114
    Rate: 654
    If you are sure that there is something going on on the CB radio in your area apart from the 19th channel (which is being replaced by Janosik) then the antenna is OK - 5/8 lambda is the most optimal type of antenna.
    As for the radio - ALAN 28 is already a grandpa. Of course there are supporters and they all convince each other that these old radios are better than modern ones. Generally, quite good pieces are also produced today, and those from the last century are often densely tired. Often "overclocked" from 4W to 6W (which gives nothing anyway). Many devices in that era were "IMPROVED" by home-grown professionals with a gutter soldering iron in their hand.
    I don't know what budget you can spend - but take a look at something from SSB. For example, Chinese (although I don't know if anything outside China is being produced today) Anytone AT 6666 or CRT 9900. In my opinion, these are very interesting designs and quite well rated.
    With AM / FM I also use ANYTONE - but the mobile model is called ROAD BLUES. Despite the fact that I had the Alan28 and Alan 18, 87, President Lincoln, Superstar 360FM, Onwa MK2, Cobra 19, Cobra 75 WX, Dragon SY101 you mentioned, this Chinese beats them all over the neck.
  • #6 17389887
  • #7 17390288
    Jap
    Help: 114
    Rate: 654
    KPO does not have good opinions. Hence their prices on the secondary market.
    Yes, this Chinese apollo road blues obviously beats Lincoln in its AM (used in PL) capabilities (amazing dynamics, not to mention ASQ - works AWESOME). During propagation, I threw Lincoln's car into the seat. I did some tests at 19AM - Lincoln went to the closet, finally changed hands.
    Not only that - people write that at the same time Anytonoe falls out even pale President William.
    But it is a mobile radio, not a stationary one, so it does not apply to the topic.
    ps recently I bought a very nice stationary CB radio STABO XF5012 (UNIDEN PA351AB board), internal power supply, beautiful audio from a large speaker, RX and TX tone reg !, ready for DTMF etc ... STABO seems to be a hi end uniden.
    Unfortunately, it is for the German market, so the AM modulator is built on a transistor and has power and range limitations in AM modulation. Somewhere I found a description that it was converted to a Polish standard and people were very pleased with the work of this equipment.
    Very decent construction, very good materials.
    The radio was working, but I am converting it to a 2-band ham transceiver so with a tear in my eye I cut out the middle.
    after conversion:
    Sometimes you can buy such stationers for pennies - but you need to have a little skill to bring them to the Polish standard.
  • #8 17390445
    gumisie
    Help: 1667
    Rate: 2489
    It is not appropriate to compare others with yourself (gutter soldering iron). :cry:
    And this:
    Jap wrote:
    Yes, this Chinese apollo road blues, of course, in its AM capabilities (used in PL) beats Lincoln on the head
    I will leave without comment.
    Well, I don't know if buying a TRX with this type of modulation makes sense, since as it follows from:
    He is going to listen and be heard on CH19.
  • #9 17390514
    d-t-x
    Help: 15
    Rate: 59
    Gentlemen, are you still hearing at 27.555? Especially I mean other continents.
  • #10 17390756
  • #11 17390770
    Jap
    Help: 114
    Rate: 654
    Of course you can hear stations on USB 27.555. Not as often and far as in the good times of the sun's activity, but still in the summer period, the propagation is sporadic. There are many Polish-language stations (economic emigrants), many of them are close to kW :)
    gumisie wrote:
    I will bet without a comment.
    It's nice if you left the whole thing without a comment - malcontents, as usual, in abundance, and GUMISIE is a leader (leaders). Are you also on the SP7PKI forum?
    I will write again - because maybe you don't understand:
    I had BOTH radios at once and compared them on my mobile. To be precise: none of them has been modified, opened or repaired. Apollo Road Blues in AM works much better than President Lincoln - that's my opinion. For the base, of course, Lincoln is amazing and you can recommend this equipment (if someone finds a gem about which, for example, Novile).
The discussion revolves around assembling a CB radio base station setup with a desired range of at least 20 kilometers. The user considers the ALAN 28 AM/FM radio and a CTE 5/8 wave antenna at 27MHz, 6.0m in length. Responses highlight the importance of the antenna for achieving optimal range, with suggestions for alternative radios such as Anytone AT 6666 and CRT 9900, which are noted for their modern features. Some participants express skepticism about the current state of CB radio activity, suggesting that the band is less active than in the past. Concerns about the quality and reliability of older radios like the ALAN 28 are raised, with recommendations to consider newer models for better performance.
