BAOFENG UV-82: Configure to Communicate with Switell/Midland PMR, Scanner & Frequency Tips
tiutesh 47976 4
  • #1 15053707
    tiutesh
    Rate: 58
    Hello, I have in my resources (a hunting club), two Baofeng UV-82 radio, and 4 pmr Switell and Midland, while PMR has no problem (with communication), when it comes to Baofeng, I have no idea how set this radio to communicate with other PMRs.
    I would like to point out that the Baofeng radio is restored to the factory settings, the noise level is set to 2, a jump of 12.5 MHz.
    Maybe someone from the forum members will explain to me how to start the scanner to catch PMR frequencies, and how to use these radios so as not to interfere with the bands used by, for example, services.
    Regards
    NIXIE_123
    Help: 288
    Rate: 609
  • #3 15053773
    tiutesh
    Rate: 58
    Nixie_123, thanks for the table, but when I hit the keyboard, I only have this layout: xxx, xxx, not like in the table xxx, xxxxx, how to enter the frequency into the radio to 5 decimal places? and how to program in the device memory?
    NIXIE_123
    Help: 288
    Rate: 609
    https://www.youtube.com/watch?v=HeNVksuGDGU
    A slightly different radio, but I think it looks the same in use
    To hit the full frequency you have to change the step to a lower one
    For me it looks like this:
  • #5 15053829
    tiutesh
    Rate: 58
    Okay, set up thank you for your help.
