Why does an Opel Meriva A 1.6 Easytronic stall and drop to 200 rpm when shifting from 1st to 2nd gear, even with no dashboard errors?
The most likely cause is worn internal gearbox mechanics, especially the sliders/tracks for 1st and 2nd gear, so the Easytronic actuator cannot complete the shift properly and the car dies during 1→2 changes [#16614079][#16599197] The reported P1732 code fits a gearbox geometry/range problem, not the clutch [#16599197] Before condemning the box, check the hydraulic unit fluid level in the tank next to the gearbox with the engine running and 2nd gear engaged, because low fluid or air can cause similar symptoms [#16599587][#16600205] Several replies warn not to calibrate the transmission on a faulty unit, because it may end with an F error and leave the car immobile [#16614079][#16599561] If the mechanics are repaired and the control is otherwise OK, then calibration can be done [#16599766]
Hello, Opel Meriva A with easytronic, it goes out when shifting from 1 to 2, there is no response to gas and the revs drop to 200 rpm, both while driving and when stationary. Easytronic services have not encountered such a problem. Can someone direct ?? There are no errors in the box
Hello, I am glad that there is interest in the topic ... , namely, the error in the box in the controller is p1732 the geometry of the gearbox-present, with the throttle, I do not know what is happening, I understand that I have to pull the hose and look if it closes or computer? because when I do not have a computer now, I am an amateur trying to diagnose because mechanics, electromechanics, do not want to repair, as they hear easytronic, known shipping services that repair drivers are set to one problem with F on the display - I do not have it, the rest of the gears are elegant, evidently the throttle is waiting for it to receive confirmation that gear 2 is inserted. When he puts it in, we go on without any problems
Without a tester, it can be difficult to determine something, unfortunately, and what is the matter with the history of this defect, the same or after some adventure?
Hello, first time, then after three months 2, then every 2 weeks, then every 3 days, then every morning, then after each firing, now every time after changing from 1 to 2. So what I found out by reading German forums. The gearbox is most likely the sliders from some F17 model and they wear out and the gearshift motor cannot cope with the distance and the gear could be damaged. The second topic, the German service, bet the visitor on the clutch, which the forum expert denied that the error 1732 has nothing to do with the clutch but explains the worn slider of gears 1 and 2 and its tracks, which cause too large paths switching between gears. It makes sense. But as usual, the topic is dead. There are also 2 such dead topics on the electrode with this problem. I will probably download the boxes, a nice clutch, I will look at the ew swap sliders on the manual for PLN 1500 (which is not a satisfactory solution). Any other ideas tomorrow I will try to talk to the German forum to this peasant has 4 cars in easytronic, and in general easytronic is a national plague; D
Ps. It is enough to turn on the winter mode and the car does not use 1st gear, but the repair is straight from "this type has it"
If I can tell you one thing, check the fluid level in the hydraulic unit as in the tank from the thrust bearing. If there is air in the hydraulic module, symptoms may be similar.
Hello, I did not calibrate the gearbox because I was informed that after the calibration, the F may pop out and the car will not go away and it will be carried out on my own responsibility and they will not take care of the car, the calibration will be carried out when the car is taken over by my mechanic, then even when F pops up, there will be someone to fight with the subject.
i had such a case with this error code. The shifts inside the box are rubbing, so you need to repair the mechanics of the box and I advise you not to calibrate it, because it will end up with "F".
I did a similar case a month ago. The sliders approached the vectra B chest brought from the scrap metal Then calibration and hula. Added after 36 [seconds]:
pako150 wrote:
In the bearing and mechatronics?
In what mechatronics
Hello, are you from Debno near Tarnów ?? I ask you know for what purpose. I'd visit your facility with my chest as pulled out.
Oh, yesterday I started to take out the boxes, also please follow the topic, gentlemen, because I will report pasting photos of these sliders and ask for your opinion
1. Is there any way to view the 2nd gear slider without disassembling this box - the box is already on the table.
2. Number of my gearbox JE419 will parts from C419 W419 f17 and f15 models play?
Sorry to ask for a while but I like to have a plan of action. All the time I hope it's the mechanics of the box, otherwise I'll be in a pretty good shape .......
Hello, I would like to thank everyone who devoted their time on this topic, the person who correctly diagnosed "helped" and with this nice accent we can close this topic.
Create an account, log in here and be active on the forum — ads won't appear. Earn points for registering and replying.
The discussion revolves around an issue with the Opel Meriva A 1.6 Easytronic, where the vehicle shuts off when shifting from first to second gear, resulting in a drop in RPM to 200. The user reports no error codes in the transmission control unit, but a specific error code P1732 related to gearbox geometry is noted. Various suggestions are made, including checking the throttle response, calibrating the gearbox, and inspecting the hydraulic fluid level. Users speculate that the problem may stem from worn sliders in the gearbox, similar to those found in the F17 model, which could affect gear shifting. The conversation highlights the importance of diagnosing mechanical issues and the potential risks of calibration without professional oversight. AI summary based on the discussion. May contain errors.
