Opel VIVARO 2.5 (2009) - Automatic Transmission Tecshift Not Engaging Gears
bula17 17199 3
  • #1 16625958
    bula17
    Help: 52
    Rate: 295
    Hello, I have a problem with Vivaro 2009 2.5 d on a lit engine and an attempt to put in a gear pops up the gear indicator and the car does not put in gears sometimes we hear as if trying to throw in but something jumps off and there is no gear.
    With the ignition switched on, no indicator light and gears can be heard from tosses and the display shows the gear in question, there was a brake pedal sensor error on the engine, after the reset the error disappeared but there was no improvement I changed the sensor but the same. The chest connects but I can not enter the error codes, maybe someone had a similar case.
  • #2 16626673
    Ttomek
    Help: 6
    Rate: 55
    Replacement clutch ...
  • #3 16627392
    pp_pablo
    Help: 93
    Rate: 405
    Start with:
    1. On the "changing gear" you have 2 tanks. Check the amount of fluid. Hydraulic oil in one DOT4 in another.
    2. Clip the procedures for venting and adaptation (3).
  • #4 16967993
    bula17
    Help: 52
    Rate: 295
    The exchange clutch did the trick
