[Solved] Sharp LC-48CFE4042E - Dealing with Color Distortion: Matrix Type Options and Possible Fixes
Top Serwis 11985 9
How can I fix the color distortion on a Sharp LC-48CFE4042E, and what panel/matrix type is installed in it?
Use the LSC480HN08-G01 panel; it has the T-CON integrated into the matrix itself [#16604942] [#16606233] The symptoms were suspected to be a gamma/VCOM-type fault, similar to old AS15-related issues, but no service-menu or local-keyboard trick fixed the unchanged screen [#16846303] [#16845409] A USB firmware update even pushed the set into an autonomous color-pattern/heating mode, but that still did not solve the distortion [#16672191] In the end, replacing the main board healed the TV [#17092929]
  • #1 16602882
    Top Serwis
    Help: 66
    Rate: 242
    Symptom as matrix type options shown. Everything in the picture is afraid that you will need a batch to sleep the matrix.
    • Sharp LC-48CFE4042E - Dealing with Color Distortion: Matrix Type Options and Possible Fixes 20170713_154607 (Kopiowanie).jpg (268.22 KB) You must be logged in to download this attachment.
    • Sharp LC-48CFE4042E - Dealing with Color Distortion: Matrix Type Options and Possible Fixes 20170713_135635 (Kopiowanie).jpg (384.03 KB) You must be logged in to download this attachment.
    • Sharp LC-48CFE4042E - Dealing with Color Distortion: Matrix Type Options and Possible Fixes 20170712_131206 (Kopiowanie).jpg (137.48 KB) You must be logged in to download this attachment.
  • Integrated T-con board and panel layout details
    #2 16604942
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    Die name, pls ?!
    - what circuits on it (T-con integrated with the matrix)
    - not this one sometimes link
    * LSC480HN08
    * The panel has integrated T-CON
    Enter what layouts you have on the T-con board.
    MAIN BOARD T.MS3463S.711 FOR LSC480HN08
    * 48 "SHARP LC-48CFE4041K LED SMART TV
    or 49 " Link_ matrix LC490DUY-sh a1
    _____________________
    LSC480HN08-G01 matrix
    combined T-con board: 15Y_R48FF11MB7S4LV0.2
    - ICD1 RT6929
    -ICD2 RT6930
    - some other min. ICT1 large ctrl Lvds Samsung CIF6380
    * maybe LTF62B0
    AVDD_17V
    VCC: 3.3V
    VOFF_-11V
    ATD_MON_T
    ATD_MON_D
    VCC_1.8:
    VGH, VGL, etc.
    WP: 3.3V
    SCL: 3.3V
    SDA: 3.3V
    MON_L:
    MON_R:
    ps
    Eg.
    - T-con 55FU11BPCMTA3v0.0 (VTU61b2, RT6930, RT6929)
    - Philips 40PFT4101 / 60 Led TV
    Chassis: TPN16.2E LA
    Panel: TPT4001A-HN02.S
    T-CON: 15Y_40GF11BMB7S4LV0.1; LTF64B2, RT6929, RT6936
    * LED backlight: GJ-2K15 D2P5-400-D409-C4 9LED 795mm
    LED driver (backlight): integrated into PSU
    LED driver: PF7708AS
  • #3 16606233
    Top Serwis
    Help: 66
    Rate: 242
  • #4 16608476
    Top Serwis
    Help: 66
    Rate: 242
    Maybe someone knows how to enter the service menu in this model?
  • #5 16672191
    Top Serwis
    Help: 66
    Rate: 242
    Recently I uploaded via usb soft from Sharp's website. The effect is that the matrix has entered the heating / autonomous mode, colorful charts appear periodically.
    How to get out of this oppression now?
  • #6 16843940
    Top Serwis
    Help: 66
    Rate: 242
    I read the memory content of this matrix, the memory is empty FF itself.
    Probably it is supposed to be so, checked in a different matrix.
    Maybe someone knows how to turn off the `` heating '' mode on this TV?
    It can be for a fee.
  • #7 16844933
    baki
    Help: 37
    Rate: 73
    In Samsung, you just need to press the local keyboard.
    Maybe it's similar here?
    Pozdr.
  • #8 16845409
    Top Serwis
    Help: 66
    Rate: 242
    You can see that it responds to the local keyboard but the screen remains unchanged.
  • #9 16846303
    lisek
    Help: 6352
    Rate: 6883
    It looks like something with "gamma"
    * resembles the problems with AS15 (Gamma and VCOM Voitage) described long ago
    Datasheet RT6908 link
  • #10 17092929
    Top Serwis
    Help: 66
    Rate: 242
    Replacing the motherboard heals the TV.
The discussion revolves around the Sharp LC-48CFE4042E television experiencing color distortion issues, potentially linked to the matrix type options. Users inquire about the T-con board configurations and possible fixes, including entering the service menu and addressing a "heating" mode activated after a software update. The LSC480HN08-G01 matrix is identified, and suggestions include checking gamma settings and replacing the motherboard as a potential solution to restore functionality.
