Cavion Base 10 3GR Quad Tablet - Issues with Starting and Accessing Recovery Mode
virers 12114 12
How can I restore a Cavion Base 10 3GR Quad tablet that only briefly shows a battery icon and will not enter recovery mode?
If recovery mode will not open, reflash the tablet with Flash Tool instead. Load the `MT6582_Android_scatter.txt` file from the firmware package, enable USB mode and DA Download All / High Speed, turn the tablet off, press Download (F9), then connect it by USB; the process should show red, purple, and yellow progress bars and finish with a green circle [#16617403] The firmware package linked in the thread is the latest available and is about 400 MB [#16616157][#16616728] If the tablet is still under warranty, the recommended solution is to send it to the Cavion service rather than trying to repair it yourself [#16631382]
  • #1 16615755
    virers
    Hello, I have a problem with running the Cavion Base 10 3GR Quad tablet. I do not know if the firmware has sat, when switching on, a light icon of a charged battery appears in the middle of the screen only for a moment. I try to press the power button and volume buttons simultaneously to enter the recovery mode, but it does not work.
  • #2 16615954
    Fak7
    And how is it connected to the cable or not?
  • #3 16615991
    nutergsm
    Help: 1034
    Rate: 1666
    Is the connected charger the same? The computer detects the tablet?
  • #4 16616157
    Freddy
    Help: 1394
    Rate: 2821
    If so then HERE you have firmware, loading using FlashTools.
  • #5 16616710
    virers
    Hello, gentlemen, so yeah. I connected the tablet to the charger and pressed the on and off button simultaneously, the battery still shows a 96% charge in the middle. I use the Linux system and it does not detect it and the smartphone detects it. I see that this FlashTools program is under Linux in the version http://www.flashtool.net/downloads_linux.php
    Is this the latest firmware version anyway? Cavion Base 10.part07.rar Download (39 MB)
  • #6 16616728
    Freddy
    Help: 1394
    Rate: 2821
    The latest available - all about 400MB.
  • #7 16617276
    virers
    Is there any description of how to upload the firmware with this FlashTools program?
  • SP Flash Tool firmware flashing steps for MT6582
    #8 16617403
    Freddy
    Help: 1394
    Rate: 2821
    - Run Flash_tool.exe
    - Select a the MT6582_Android_scatter.txt in ROM
    - Wait file to be added into Flash Tool
    - choose Option->USB Model,click USB Model
    –> Choose Option->DA DownLoad All->Speed->High Speed, click High Speed
    - Turn off your tablet.
    - "Press F9 (hit Download button)" OR " if upgrade ROM Firmware->Upgrade "
    - and connect your phone into the computer via USB data cable.
    - The process will start and a red progress bar will appear after color purple, yellow.
    - And green circles display
    - Finish !
    - You can now safely disconnect your phone and turn it on.
  • #9 16631352
    virers
    Hey, and you can write to me how to make a hard reset in this tablet, which buttons, I have it only a year ago. So the warranty is still there, maybe tomorrow I will take him to the site.
    Freddy
    Help: 1394
    Rate: 2821
    If it's on the warranty, I do not know why you're up to it?
    Freddy
    Help: 1394
    Rate: 2821
    Why are you going to the store?
    Pack the tablet carefully, preferably in the original box and bubble wrap. Send it to the following address:
    CAVION service
    ul. Głowackiego 1
    28-500 Kazimierza Wielka
    Attention! We recommend sending a registered parcel.
    http://cavion.pl/
  • #13 16638475
    virers
    Thanks, already sent to the site.
    The tablet is already working, they exchanged the motherboard.
The discussion revolves around issues with the Cavion Base 10 3GR Quad tablet, specifically difficulties in starting the device and accessing recovery mode. The user reports that the tablet briefly displays a battery icon upon startup but fails to boot. Various responses suggest checking the charger connection and compatibility, as well as using FlashTools for firmware updates. The user mentions using a Linux system, which does not detect the tablet, while a smartphone does. There is a request for instructions on uploading firmware and performing a hard reset. Ultimately, the user resolves the issue by sending the tablet for service, where the motherboard was replaced.
