Cavion Base 10 3Gr Quad: Seeking Firmware for Sofia3gr Android 5.1.1 Cavion 10 3GRQ V2.0.1
blebe 5817 4
  • #1 16820090
    blebe
    Rate: 15
    I am looking for a tablet software for Cavion Base 10 3 Gr Quad. The tablet turns on and hangs on the Android logo. It is possible to run in recovery mode and to download the software from a memory card. Currently installed system is Sofia3gr Android 5.1.1 Cavion 10 3GRQ V2.0.1 which I can't find and Cavion doesn't provide software. I tried to backup using adb however there is a message that the tablet is locked.
  • #2 16820257
    gradek83
    Help: 930
    Rate: 2105
    write to cavion Enter model and serial number and ask for firmware.
    And anyway, in recovery mode did you enter wipe options?
  • #3 16820436
    blebe
    Rate: 15
    I wrote to Cavion and unfortunately the answer that they do not provide software, which I stated in the post. So in recovery mode I did the wipe option and nothing helps.
  • #4 16820626
    gradek83
    Help: 930
    Rate: 2105
    If you still have it under warranty, use it if not, maybe look for a twin version of this tablet from another manufacturer by motherboard number. Unless your memory is damaged, you have a chance.
  • #5 16829254
    blebe
    Rate: 15
    Unfortunately, the tablet is no longer under warranty so it remains to look for, or the Cavion service.
    I sent the tablet to the Cavion website and unfortunately the description of the damaged disc, so the subject to be closed.
