[Solved] JBL Xtreme Speaker: Understanding Low Frequency Mode & Other Settings with Bluetooth+Volume Key
RiNgVaY 124776 11
How do the Bluetooth + volume button combinations work on a JBL Xtreme, and why does Bluetooth + volume up cycle through strange modes instead of just toggling bass mode?
On JBL Harman speakers, the normal low-frequency mode is usually activated by holding Bluetooth + volume down (minus) for about 10 seconds, and that combination should toggle between normal and LFM modes. [#16617711] Bluetooth + volume up is generally a hidden service mode, not the bass mode, and on the Xtreme it can even switch the speaker off rather than just changing sound modes. [#16617711] [#16910099] For the Xtreme, one user reports that Bluetooth + + turns the speaker off, while Bluetooth + - enters low-frequency mode, so the two button combinations do different things. [#16910099] After entering the service mode with Bluetooth + +, the micro-USB port becomes active, which supports the idea that this is a factory/service function rather than a normal listening setting. [#18179807] If you want to turn off the low-frequency mode again, use the same Bluetooth + minus hold for about 10 seconds until the buttons light up and go off. [#16621193]
  • JBL Xtreme enters multiple woofer test modes
    #1 16617357
    RiNgVaY
    Hello. I was looking for a solution on various websites but nowhere is there any information about these modes.
    I have a Jbl Xtreme loudspeaker and wanting to turn on the low frequency mode (bluetooth + volume mark) I have encountered strange modes. Subsequent switching after holding the combination (bluetooth + increase the volume).
    It starts with the altogether turning off the woofers, the next mode switches on the woofers and high and the last switches only the woofers, turning off the woofers. If anyone has any information regarding information regarding these modes please leave a comment
    (I will add that the colleague has charge 3 and normally switches between low and normal modes, he does not jump to other modes)
  • Bluetooth and volume keys enter hidden speaker modes
    #2 16617711
    kamkamilo6
    Rate: 11
    Of course, this normal lfm mode is activated by holding down the bluetooth button and minus for about 10 seconds in all harman wireless speakers. In each loudspeaker, pressing such a combination of keys are only 2 modes lfm and plain. After holding the bluetooth and plus are in most cases the service modes (charge 2+ exception, so it is updated). These are hidden modes so it is normal that after putting the loudspeaker to the site, the service uses these modes to check that each speaker plays as it should.
  • #3 16617736
    398216 Usunięty
    Help: 3925
    Rate: 9449
    RiNgVaY wrote:
    the last turns on only the woofers, excluding the woofers.
  • #4 16620917
    sebqwerty
    Rate: 11
    I have a question how to turn off the low-frequency mode in jbl charge 2+
    how to disable the woofer mode in jbl charge 2+?
  • #5 16621193
    kamkamilo6
    Rate: 11
    Just as you turned it on you hold down bluetooth and minus for about 10 seconds until all the buttons are on and off.
  • #6 16910099
    KSI AUDIO
    Help: 6
    Rate: 28
    I also have Xtrema and I do not have such modes. When you press the + and Bluetooth keys, the speaker turns off. Only after holding the bluetooth i - the speaker enters the low frequency mode. Regards and check if you're really pushing good keys ;) Merry Christmas
  • #7 17705579
    Zapp
    Rate: 15
    Hello!
    I will play the cutlet.
    My jbl boombox probably works in the bass mode, because after holding - and bt enters the mode of soprano and cuts off the low ... (nice option if someone is too loud and the signal device has no equalizer) after switching off the speaker and turning back comes back to static settings and it does not matter if I do this in external mode or in the external mode (pstrip in the back), but when you press plus and bt, the LEDs turn on and the speaker turns off ... I hope something does not set, hard reset is not is because I have welcome sounds turned off and the standard is included.
  • #8 17705678
    zaqqqaz
    I will join the topic.
    As a happy Charge 2+ owner, I have a question, why update the loudspeaker ?? What is the sense in principle?
  • #9 17715625
    Zapp
    Rate: 15
    For example, in charge 3 so that instead of connecting 2 loudspeakers with each other, it is possible to over 100 so-called jbl connect to connect + and np so that you can turn off these funny sounds of switching on / off / connection bt.
    I noticed such two differences, rather no sound in the sound.
  • #10 18179807
    energotomi
    Rate: 18
    After entering the service mode (Bluetooth and +) the micro USB port is active, does anyone have knowledge of what I can do using this connection or software enabling PC communication -> speaker?
  • #11 18323171
    kubadusieq
    Rate: 16
    I wanted to turn on the subwoofer mode in Jbl Flip 5 and I showed myself a red light and I can't do anything :(
  • #12 18329560
    KSI AUDIO
    Help: 6
    Rate: 28
    You've probably reset it. Connect it to the power supply, let it charge and write what to do next.
The discussion revolves around the JBL Xtreme speaker and its low-frequency mode activation process. Users share their experiences with different JBL models, noting that the low-frequency mode can be activated by holding the Bluetooth and volume down buttons for about 10 seconds. Some users report encountering unexpected service modes when pressing the Bluetooth and volume up buttons, which are not standard modes for the Xtreme. Comparisons are made with other models like the JBL Charge 2+ and Charge 3, highlighting differences in mode activation and functionality. Users express confusion over the various modes and seek clarity on how to manage them effectively.
