[Solved] Troubleshooting JBL Charge 3 Low Frequency Mode: Self-Activation & Reset Solutions
Masno ni 31446 3
  • #1 17671361
    Masno ni
    Hello, I have a problem with my jbl charge 3. When I turn on the loudspeaker, the low frequency mode turns itself on. It's annoying when I want to listen to music normally. I have already reset the speaker and nothing has helped :(
    telecaster1951
    Help: 829
    Rate: 818
    Hold the bluetooth button and the volume down for 10 seconds (until the battery LEDs flash). When it turns off, see if any of the buttons is "pressed" by holding only one of them. If it continues to turn on by itself, it means that you have a damaged electronics.
  • #3 17672863
    Masno ni
    I checked and everything is ok. But it's the electronics' fault :(
  • #4 17674345
    Masno ni
    Added after 8 [hours] 37 [minutes]:
