[Solved] JBL Xtreme Speaker Charging Guide: Battery Charging Time, Indicators & Tips
Dj_Majster 69048 8
  • #1 17050352
    Dj_Majster
    Rate: 41
    I have not found anywhere in the JBL XTREME speaker manuals that were included in the charging information set:
    - when will I know that the battery is charged?
    - how much time should the speaker load?
    I am asking for a detailed answer about charging if you know something about it.
  • Charging time and battery capacity discrepancies noted
    #2 17050546
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    The time of charging the battery at full discharge, ie when the device turns itself off is 3.5 hours, the duration of operation is about 15 hours depending on the volume and type of music. The level of charge is indicated by the diodes on the bottom of the loudspeaker, there are large discrepancies in the manual, says 2000 mAh and 5000 mAh, and 10,000 mAh on the manufacturer's website or in reviews, so the charging time can be much more than 3.5 hours. There were several posts on the forum that people with speakers from this manufacturer reported a problem with charging the battery after the situation in which the speaker turned itself off while playing because the battery is discharged, so it is better not to lead to such a situation and recharge the battery if we have the opportunity.
  • #3 17050593
    Freddy
    Help: 1394
    Rate: 2821
    After all, all this information is in the instruction manual.
  • #4 17050690
    Dj_Majster
    Rate: 41
    Actually there are diodes that are flashing while charging this speaker. However, I left the loudspeaker for 7 hours and the last LED was still flashing.
    There is no information in the manual about when the user will know that his device is charged. What's more, there is no given time after which the loudspeaker will be charged. Unless Freedy you have one in which it is written is to share because such a statement does not help.
  • #5 17050720
    Freddy
    Help: 1394
    Rate: 2821
    The first better found in the network, and delivered with the equipment - charging time of 3.5 hours. What do you complain about, do not you read the instructions?
  • #6 17051018
    Dj_Majster
    Rate: 41
    And here you are wrong because I read. and I do not have a grudge. And what about the diodes when charging?
  • #7 17146254
    Dj_Majster
    Rate: 41
    I received such answers from a JBL representative:
    LEDs on the speaker indicate the battery level, the fifth flashing white LED indicates the maximum charge.
    Charging time to fully charge the battery needs 3.5 hours.
    In the JBL Xtreme loudspeaker, you can hear the quiet noise caused by the power supply. This is the normal behavior of JBL wireless speakers.
    Greetings,
    Tomasz Nowicki
    Tel: +48 32 258 08 98
    Fax: +48 32 203 45 09
    www.jbl.com
    www.akg.com
    www.harmankardon.com
    I asked in detail but it did not help:
    The last LED should be permanently lit, if during charging the diode blinks, please disconnect the charging and check the diode's behavior. If it is steady, please check the battery life. If the diora still blinks, please connect for further charging.
    Greetings,
    Service department
    www.jbl.pl
    As for me, the answers are not full. There is no information about whether the last diode during charging should flash or stay on. At my place it flashes even after 5 hours of charging. So you really do not know when the loudspeaker is fully charged. No sound signal or specification regarding LEDs, i.e. flashing / continuous light.
    Does anyone know anything about this?
  • #8 17146263
    Freddy
    Help: 1394
    Rate: 2821
    After all, you have clearly written whether to blink or shine and what to do as it blinks.
    If the equipment is under warranty, please return it to the service for repair.
    If it is not under warranty, please measure the feet and make basic measurements.
  • #9 18016888
    Dj_Majster
    Rate: 41
    The speaker was under warranty. It turned out that the battery was the culprit - a faulty battery. Now it charges properly and the LEDs when it charges shine continuously, not the last one blinking all the time as it was before.
The discussion centers around the charging process of the JBL Xtreme speaker, specifically addressing the lack of clear information in the manual regarding charging time and battery indicators. Users report that the speaker takes approximately 3.5 hours to charge from a fully discharged state, with operational time around 15 hours depending on usage. However, there are discrepancies in the manual regarding battery capacity, leading to confusion about charging duration. Users note that the LED indicators do not provide definitive information on when the speaker is fully charged, as the last LED may continue to flash even after extended charging periods. Some users suggest contacting JBL for clarification, while others recommend returning the device for service if issues persist.
