[Solved] JBL Xtreme 2 Not Turning On: Connect+ & Volume Up Button Issue - Troubleshooting Tips
ANALbert 30789 9
  • #1 17379735
    ANALbert
    Hello, I have jbl xtreme 2 and at the same time I squeezed the connect plus button and the volume up button, the speaker has turned off and I can't turn it on now, what should I do?
  • #2 17379777
    stalker1995
    Help: 54
    Rate: 104
    Hard topic, battery charged?
    Use the reset button should be somewhere in the back (needle preferably) check if it moves.
  • #3 17513714
    leniu171
    Rate: 28
    I also did it by accident so much that in xtreme 1 and nothing works. It reacts to the charger, the switch lamp lights up. Has anyone dealt with this problem?
    Greetings.
  • #4 17557113
    kacperos9371
    Help: 13
    Rate: 145
    Hold the conect and the plus button on the connected charger simultaneously, it should reset.
  • #5 18570141
    fronek22
    Rate: 94
    Greetings.
    Buddy, you coped with this topic, which is the same for me, loads, but so does not turn on does not respond to any of the buttons
  • #6 18598476
    kacperos9371
    Help: 13
    Rate: 145
    conect and + hold on and reset
  • #7 19791318
    bartoszgontasz39
    Rate: 17
    And what if the speaker does not respond after the reset via the Connecticut and buttons
    Added after 31 [seconds]:
    conectu and - *
  • #8 19792206
    kacperos9371
    Help: 13
    Rate: 145
    conect and +
    the charger must be connected
  • #9 19792226
    bartoszgontasz39
    Rate: 17
    Nothing changes, they turn off and you can not turn it on or nothing you need to unplug the akusa, connect it and the same turns on and does not work and I do not know what zrovix does anyone have any idea?
    Added after 11 [minutes]:
    I have dealt with the problem, but there is one more question, where can I buy a diaphragm for the JBL Xtreme 2 loudspeaker, does anyone know?
  • #10 19796507
    kacperos9371
    Help: 13
    Rate: 145
    Search on popular auction sites.
✨ The discussion revolves around troubleshooting the JBL Xtreme 2 speaker, which has stopped functioning after the user accidentally pressed the Connect+ and Volume Up buttons simultaneously. Several users suggest checking if the battery is charged and using the reset button located at the back of the device. A common solution involves holding the Connect+ and Volume Up buttons while the speaker is connected to a charger to perform a reset. Some users report that their speakers respond to charging but do not turn on, indicating a potential deeper issue. Additionally, there are inquiries about purchasing replacement parts for the speaker, such as the diaphragm.
