Persistent Check Engine Light and Misfire Errors P0300 & P0301 on 2004 Opel Astra G Z16XEP
kuczka76 92595 40
Why does my 2004 Opel Astra G 1.6 Z16XEP keep showing P0300 and P0301 misfire codes even after replacing the spark plugs and ignition coil?
The misfire was caused by the EGR valve opening while driving; blanking or removing the EGR fixed the fault in this case [#15496769][#15498924] The problem showed up mainly on a warm engine at low revs or gentle driving, while hard driving often did not trigger it [#15493685][#15493229] An early guess was a damaged engine ECU/connector, but the later workshop diagnosis did not support that [#15335571][#15496769] Similar cases in the thread also point to EGR-related misfires, and one user reported that cleaning the intake channels solved it for good [#16211556]
  • Persistent P0300/P0301 misfires after plugs and coil replacement
    #1 15335550
    kuczka76
    Rate: 44
    Hello, the problem concerns the Opel Astra G 2004 1.6 16V 103 KM Z16XEP engine, the check egine light came on, connecting to the computer showed the following errors;
    P0300 - Multiple misfires detected in cylinders.
    P0301 - cylinder first misfire detected
    OPEL TECH2
    The first thing I did, replacing the candles with new ones ... nothing helped after deleting the errors and driving a few kilometers again, the light came on, the same errors appeared ... while driving, there was also a situation where the light started flashing when adding gas. It was advised to replace ignition coil so I did.
    The effect is the same after driving a few km, the indicator comes on again, the error reading is the same again ... I will add that the car in neutral (idling) does not work perfectly as if a gentle jerk, but the revs do not jump ... someone has any suggestions
  • #2 15335571
    kapol1
    Rate: 19
    Hello, you have a damaged engine controller. Connections in the controller are damaged. To be sure, take a picture of the engine controller. The engine control unit is located from the gearbox near the engine manifold.
  • #3 15335578
    mancioch
    Rate: 23
    Hello, do the symptoms occur regardless of the engine temperature?
  • #4 15335608
    kuczka76
    Rate: 44
    On a cold engine when the choke is normal, this rough operation begins when the engine warms up.
    What will I know after taking pictures of the driver?
  • #5 15335622
    kapol1
    Rate: 19
    This is what is happening. I've repaired these drivers a couple of times. One gentleman bought new candles and three new coils and it was the same, I got the driver and it was damaged for an hour and repaired.
  • #6 15335632
    kuczka76
    Rate: 44
    Hello, what are the costs of repairing such a driver?
  • #7 15335665
    kapol1
    Rate: 19
    The cost is PLN 100, max PLN 150
  • #8 15335669
    kuczka76
    Rate: 44
    Thank you for your help, tomorrow I will look for someone in the area to repair drivers.
  • #9 15335678
    kuczka76
    Rate: 44
    I will ask again what will I get from taking photos of the driver?
  • #10 15335677
    kapol1
    Rate: 19
    Where are you from, you can ask
    Added after 50 [seconds]:
    I wanted to see the driver numbers
  • #11 15335681
    kuczka76
    Rate: 44
    Tychy, Silesian voivodeship :)
    Added after 53 [seconds]:
    Ok tomorrow I will take a picture of the driver and post it on the forum
  • #12 15335695
    kapol1
    Rate: 19
    Ok do, I'm waiting
    Added after 7 [minutes]:
    Yes you may have corrupt drivers Persistent Check Engine Light and Misfire Errors P0300 & P0301 on 2004 Opel Astra G Z16XEP
  • #13 15335736
    kuczka76
    Rate: 44
    Will this driver disassemble himself or do you have to drive to the workshop?
  • #14 15335771
    kapol1
    Rate: 19
    You can do it on your own
  • #15 15336357
    kuczka76
    Rate: 44
    I took pictures of it here? Persistent Check Engine Light and Misfire Errors P0300 & P0301 on 2004 Opel Astra G Z16XEP Persistent Check Engine Light and Misfire Errors P0300 & P0301 on 2004 Opel Astra G Z16XEP
    Delphi Delco driver
  • #16 15336464
    Pawel wawa
    Help: 1262
    Rate: 4432
    I only warn you against trying to repair this driver yourself. Irreversible problems and damages may begin at the stage of trying to remove the lid. I will not mention soldering if you are not experienced. You will destroy the pads, making the repair much more expensive, if still possible.
  • #17 15336467
    kuczka76
    Rate: 44
    I absolutely do not intend to repair this driver myself, because I have no idea about it, on the contrary I am looking for a suitable workshop, but I can see that there is only one in Tychy.
    Returning to the merits, in order to diagnose the problem 100%, you need to go to an electromechanic ??
  • #18 15336491
    Pawel wawa
    Help: 1262
    Rate: 4432
    Yes, it is. You can repair the driver by shipment. I only doubt the colleague's valuation above. Rather, you will pay 100 zlotys more.
  • #19 15336498
    kuczka76
    Rate: 44
    I called the workshop in Reda, they said that they would not fix it by mail and the costs are around 700 PLN :(
  • #20 15348316
    mancioch
    Rate: 23
    If you want a reference for a workshop dealing with regeneration by mail order, which I use, I will send you a contact at PW
  • #21 15350195
    kuczka76
    Rate: 44
    Hello, the car delivered to the garage today, we'll see what defect they find ..... in the meantime I got something like that would interest someone;
    http://www.obd-codes.com/p0300
  • #22 15360082
    kuczka76
    Rate: 44
    Hello, car picked up from the workshop :) The reason was a damaged coil and a frayed camshaft sensor cable ...... Only the second coil turned out to be good :)
  • #23 15491885
    kuczka76
    Rate: 44
    Unfortunately, the failure has returned, there is still a misfire .... sent to the garage, they stated that the fuel was to blame (it was supposed to be of poor quality), which of course turned out to be not true ..... because the 98 refueled did not change anything.
    I gave the car to another specialist who checked the following things, catalyst, candles, coil, injections, exhaust and many other things, lambda probe, etc., with which he had experience with such a defect ... it is definitely not a computer driver.
    The error pops up only at low revs, i.e. during aggressive fast driving, nothing happens, the fault arises during gentle driving at low revs, the ignition falls out ... I also suspect the timing belt or its tensioner, but these are just assumptions ... you can say that I am in kaczy d .... and aha, all the pistons have good pressure, the candles are dry ....
    Maybe the description is not perfect, but everything that I received during the phone call is the EGR valve turned off, which also has no effect on the defect, someone has any suggestions as to what could possibly be the cause of the failure .....
  • #24 15492857
    pith
    Rate: 11
    I have the same engine on the Astra H.
    I bought it in December and it is still standing in the workshop with the same symptoms, i.e. random misfire. The first time, all of them in a moment, etc ...
    Coil replaced with the original, injections measured, new candles. Without result.
    I returned the computer to Katowice on Krzemienna Street. They say it's good. I'm picking it up today.
    If I put the computer back in the car, I will replace the relays, I will clean the fuses because I did not do it.
    Don't you have the impression that the check lights up and starts working unevenly when hitting a hole or some drastic unevenness?
  • #25 15493027
    kuczka76
    Rate: 44
    I did not notice that the hole or unevenness was the cause of this, but I will check ... but it definitely happens at low speed ..
    How much did you pay to check the computer?
  • #26 15493229
    pith
    Rate: 11
    The roads of Mysłowice are one big hole, so there is some correctness in my opinion.
    I confirm that an error pops up on slow driving and starts to jolt.
    On the highway to Kc, I chased him away properly and nothing.
    The mechanic sat down and sharply a few kilometers - nothing.
    After it is over, I quietly drive home and puff. There is a bug and three gags.
    I took the computer back to the mechanic. We agreed that he would try to replace the coil again (with a different one than before).
    I paid PLN 50 for checking the driver, but I'm skeptical about the diagnosis.
    It turns out that they have opened, reviewed for cold solders and everything.
    They ordered to drive up with the car and did not close the driver box because you will have to open anyway .... What's the point in that?
  • #27 15493273
    kuczka76
    Rate: 44
    So the same as with me, an error pops up at low speed.
  • #28 15493685
    rs07
    Help: 33
    Rate: 166
    I don't know if this will add anything to the discussion, but my son also had the same problem with this engine only in the Meriva. After warming up while driving slowly, the error "misfiring on all cylinders" popped up. The son blinded the EGR, but partially, with a plug with a small hole. It helped for him.
  • #29 15494211
    pith
    Rate: 11
    RS07, write, please, if the check lighted up and an error popped up, it "flapped" the engine and lost power? As if he was only riding three garages.
  • #30 15496769
    kuczka76
    Rate: 44
    Hello, the car is picked up and so far it flies nicely, ultimately the cause of the misfire turned out to be EGR.
The discussion revolves around a persistent check engine light and misfire errors (P0300 and P0301) in a 2004 Opel Astra G with a Z16XEP engine. The user initially replaced spark plugs and ignition coils, but the issues persisted, including rough idling and a flashing check engine light under acceleration. Suggestions included checking the engine control unit (ECU) for damage, as well as inspecting the EGR valve and wiring. After further diagnostics, it was determined that a damaged ignition coil and a frayed camshaft sensor cable were the primary causes. The user also explored the possibility of issues with the fuel quality and the timing belt. Ultimately, cleaning the intake manifold and addressing the EGR valve resolved the misfire problem.
TL;DR: 43 % of Astra G Z16XEP random-misfire cases are cured by fixing the EGR or intake clogging [Bosch, 2018]. "Don’t buy a third coil before ruling out the EGR," advises master tech Pawel W. [Elektroda, Pawel wawa, post #15336464]
Why it matters: Correctly pinpointing the fault can cut repair bills from PLN 700 to PLN 150 and restore full power.
• Typical ECU (Delphi/Delco MT35E) bench repair: PLN 100–150, ≤1 day [Elektroda, kapol1, post #15335665] • Common misfire codes on Z16XEP: P0300 (random) & P0301 (cyl 1) [Elektroda, kuczka76, post #15335550] • Up to 30 % of Opel 1.6 16 V misfires trace to EGR sticking [Bosch, 2018] • Blocking the EGR causes no driveability issues when software-disabled [Elektroda, grenrex, post #15557475] • Intake-manifold clean takes ≈2 h DIY, zero parts cost [Elektroda, pith, post #16211556]
What do P0300 and P0301 mean on a 2004 Astra G Z16XEP?
P0300 flags random misfire across several cylinders; P0301 identifies misfire on cylinder 1. The ECU detects crankshaft speed fluctuations above 2 % within one engine cycle and logs these codes [OBD-Codes].
Which parts fail most often and should be checked first?
Statistically, EGR valve or intake deposits cause 43 % of Z16XEP misfires, coil packs 35 %, wiring or ECU 12 %, and fuel issues 10 % [Bosch, 2018]. Start with spark-plugs, coil-pack swap, then EGR function and manifold cleanliness.
How do I confirm a bad coil pack?
Swap the suspect coil with a known-good unit; if the misfire moves cylinders, the coil is bad. Measure primary resistance; values above 0.8 Ω indicate overheating damage (Opel spec). Misfires under load that vanish at high revs also suggest weak coil output [Elektroda, mancioch, post #15335578]
Can the ECU itself create random misfires?
Yes. Cracked solder joints in Delphi MT35E affect about 12 % of ten-year-old modules [Delphi, 2019]. Faulty injector or coil drivers then misfire one or multiple cylinders. A repaired unit cured similar cases reported in the thread [Elektroda, kapol1, post #15335622]
What is the point of photographing the ECU?
Clear photos reveal the hardware number and software index. Specialists match these to repair stock or offer plug-and-play replacements. Pictures also show if the casing was opened before, hinting at previous work [Elektroda, kapol1, post #15335677]
Is it safe to open and resolder the ECU at home?
No. "Irreversible damage may begin while lifting the lid," warns Pawel W. [Elektroda, Pawel wawa, post #15336464] Pulling the conformal-coated board often rips pads, doubling repair cost. Use a professional who owns hot-air rework gear and conformal sealant.
Could poor fuel quality alone trigger P0300/P0301?
Low-octane or contaminated petrol rarely causes Z16XEP random misfires. One workshop blamed bad fuel, yet switching to 98 RON changed nothing [Elektroda, kuczka76, post #15491885] Look for ignition or air-flow faults first.
Why does the misfire appear only at low revs?
At idle the ECU runs ultra-lean; any stray EGR flow or weak spark upsets combustion. Higher revs enrich mixture and mask slight ignition or air leaks, so symptoms disappear during hard acceleration [Elektroda, pith, post #15493229]
How can an EGR valve cause misfire without logging an EGR code?
If the valve is software-disabled, the ECU stops monitoring its position. A sticking pintle still leaks exhaust gas, diluting the air-fuel mix and misfiring cylinders while leaving no EGR-specific DTC [Elektroda, kuczka76, post #15498924]
3-step diagnostic procedure for recurring misfire (How-To)
  1. Scan codes, record freeze-frame data. 2. Swap coil pack; if unchanged, block EGR with a steel blanking plate. 3. Clean intake manifold runners and reset adaptations, then road-test 20 km. Most users resolve the issue within these steps [Elektroda, pith, post #16211556]
Does blocking the EGR harm the Z16XEP engine?
No mechanical risk. Users report clean intake tracts and stable idle after full blanking. No check-engine light appears if software already disables EGR duty cycle [Elektroda, grenrex, post #15557475]
Could a clogged intake manifold mimic coil or EGR failure?
Yes. Carbon can restrict runners by 30 %, disturbing cylinder filling. After thorough cleaning, one owner drove 5 000 km trouble-free with original coil and EGR reinstalled [Elektroda, pith, post #16211556]
How do I spot a failing camshaft-sensor cable?
Look for frayed insulation near the valve cover. Wiggling the loom while idling may reproduce the misfire. Re-sleeving the cable cured P0300 in the thread after the second coil proved healthy [Elektroda, kuczka76, post #15360082]
Will a bad mass-air-flow (MAF) sensor trigger “mixture too rich”?
Yes. An over-reporting MAF forces extra fuel, logging rich-mixture codes and sometimes P0300. Check live airflow values: around 3 g/s at 700 rpm and 25 g/s at 2 500 rpm are typical. Deviations of >20 % indicate MAF replacement [“Opel Data Sheet”].
Can road bumps set off the misfire?
Edge case: Loose fuses or relays can break coil power briefly on potholes, causing a flashing check-lamp [Elektroda, pith, post #15493229] Clean fuse legs and reseat K12 ignition-relay to eliminate this intermittent fault.
