Hyyker X Range E Keyboard: Issues with Keys Not Responding - Causes & Solutions
XezolPL 5634 9
Why do some keys on a mechanical keyboard stop responding, and how can I fix it?
The fault is likely in the switch’s microcontact/metal contact, which may be dirty, bent, or worn out, and washing the keyboard can make it worse rather than better [#16621749] For this type of keyboard, the safe approach is to disassemble the switch, check whether the protruding metal pin/contact is bent, and straighten it if needed before reassembling [#16675239] If the contact is worn, the practical repair is to replace that switch with another same-size switch from a rarely used key such as Scroll Lock or Pause/Break, provided the mechanical dimensions match [#16621749] Avoid pouring water or cleaning fluids into the whole keyboard, because they can cause dirt to stick to the contact and create additional damage [#16621749]
  • #1 16620432
    XezolPL
    Rate: 8
    Hello, as in the title, nwm, what is caused by the fact that sometimes they are used, I do not write, I am terribly irritated, formerly it wasn't: / greetings and please help
  • #2 16620469
    osiniak75
    Help: 350
    Rate: 544
    Buy a new keyboard, do not throw away the old one but dispose of it at an electronic waste collection point. This is very important because it helps to care for our natural environment in which our grandchildren will grow up one day. greetings
  • #3 16620479
    XezolPL
    Rate: 8
    I want to fix it
  • #4 16620521
    osiniak75
    Help: 350
    Rate: 544
    If you want to fix it, go ahead, put a screwdriver in your hand and get to work.
  • #5 16620567
  • #6 16621492
    XezolPL
    Rate: 8
    Nwm, and what can it be caused by? I have no guarantee but there is a lot of dust, maybe because of it? I cleaned it with dust and I heard that the keys were rinsed with running water and the keyboard thoroughly cleaned with sticks and if a button broke, give some alcohol inside. How much truth is there?
  • #7 16621595
    398216 Usunięty
    Help: 3925
    Rate: 9450
    XezolPL wrote:
    what can it be caused by? ... there is a lot of dust,
    It is necessary to unscrew it gently and carefully, clean it from dust and wash it under running water (a little detergent for the brush can help remove old dirt) the case - hello with the keys first of all. There is a plate under the keys (two foils with dusted paths and contact fields most likely) - keep water away from it. This plate (but if it is dirty) can be tried to gently rinse with IPA (isopropanol) an ear stick or a cotton swab in wetted IPA. Dry, fold and check if it works. Like this - I will work the same as before, and there will be problems - the films are worn and you will do nothing; or utilization.
    You can try.
    PS When washing the paths on foil (if it's such a construction) be careful - contrary to appearances, they are quite delicate.
    My current keyboard is already 6 years old on the meter and works after washing three times. The trouble is that the inscriptions on the keys begin to wipe, and "from memory" to write I have not learned and probably will not teach. In any case, thanks to periodic cleaning I extended her life by a few nice years - which is not without significance for the environment ... ;)
    PS 2.
    Now I just looked - it can be a problem, because there is no foil in yours and there are mechanical buttons with contact plates shortened with keys ... You can replace these switches (provided that it gets ...) but the works ... pile. In addition, the cost of such an operation (buying retail switches are more expensive than wholesale) is unprofitable, and with the cleaning of switches even more work and (contrary to appearances) the cost is also considerable.
  • #8 16621680
    XezolPL
    Rate: 8
    Seriously the whole keyboard because one thing sometimes doubles, come on.
    Added after 7 [minutes]:
    I meant to wash the covers on the switches under running water, clean the keyboard after the baskets with a soaked cotton swab and touch the switch with an alcohol-soaked ear stick because I did not understand your speech. with the rest of the problem that it repeats once every 10 times but it is annoying, what can it be about, it is mechanical on blue switches, I will add that as a downloadable overlay from the switch on e this problem disappears, maybe you need to wash it / replace? can I wash it under running water?
  • #10 16675239
    XezolPL
    Rate: 8
    So for anyone with a similar problem, take apart the switch, preferably desolder with a tin sucker, but I just pulled it out, and see if such a metal protruding post is not bent or something, it should enter the hole, if it is not straighten it and put it back in the keyboard, ready.
The discussion revolves around issues with the Hyyker X Range E keyboard, specifically keys not responding intermittently. Users suggest various troubleshooting methods, including cleaning the keyboard to remove dust and debris, which may be causing the problem. Recommendations include carefully disassembling the keyboard, cleaning the micro contacts, and potentially replacing faulty switches. Concerns are raised about the risks of washing the keyboard with water, as it may lead to further damage. Users also mention the importance of checking for bent metal posts in the switches and suggest using isopropanol for cleaning. The lack of warranty complicates repair options, and some users advocate for replacing the keyboard entirely if issues persist.
